Have you tried resetting bios to default? There should be a jumper on the motherboard that says CMOS default or BIOS default. It is usually 3 pins with a jumper across 2 of them. Changing the jumper to the other unused pin and center pin, labled default, should reset bios to default and remove the password.
desconect from power, remove main batery and also need open with screw driver in orther to remove bios batery too, wait for around 5 minutes and u done. this works for me on a gateway model NV55C hope this help
Hello Sir, it'sa very easy task to get past a BIOS password but it takes a long time doing so, 1. you need to take out the batery of your computer 2.unscrew the keyboard 3. becarefull removing the keyboard there is a vire conecting it 4. if u can see a smal clock batery remove it 4.1 if you can not you got to dismantle the computer to find it 5. put it back in 6. put the parts back to gether 7. Start computer the bios password is now gone. Hope this helps
Thank you for using fixya Nikolai Langset PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Disconnect the cmos battery (remove clock batery
out) wait and insert back the batery... p.s. Bios setings setting becomes the
default date and time so the same ... Then you come into the system bios and
adjust its settings and the date and EnJoy
Hi mate, try removing all power sources, i.e. main power lead, main battery, bios battery, then press the power button for about 10 seconds to remove any residual charge on the motherboard. Apologies if you have already done this. If not update and flash to new bios... download here for your OS... http://support.acer-euro.com/drivers/notebook/as_4710.html
if is the windows administrator password press F5 then you enter safe mode and remove administrator password if is the bios password remove the motherboard batery for 5 seconds
