Question about Boston Acoustics SoundWare XS 5.1 Speaker System
Hi i have the Boston acoustics soundware xs 5.1 the sub stopped working the led shines red on stand bye and turns to green when the amp is switched on so i have taken it apart and found ZD3 has blown but cant tell what it was so I don't now what to relapse it with any help would be appreciated regards james
Posted by james on
leonardo
    New Friend:
  • 3 Answers
Hello James, did you find the value of ZD3.
I need it too.
I have the same problem, and I take out the ZD3 and the subwoofer works. But I'm not sure that is correct. I think it may be the circuit stand by.
Posted on Jul 16, 2014
  • bringa Jan 04, 2019
    the zenner ZD3 is the 1N942 11.7V
richie46
    Top Expert:
  • Boston Acous... Master
  • 12,962 Answers
ZD stands for zener diode and used for exact voltage regulation. Take out a known good one and go to a repair shop to replace. Make sure that when you re install, the striped (polarity) markings are in the same direction!
Posted on Mar 17, 2014
Testimonial: "hi i don't now the value there is only one on the bored"
  • 1 more comment
  • richie46 Mar 18, 2014
    Un solder the diode and take it down to a repair shop - or remove the entire board and take it down to shop. What ever is easier.
  • Giuseppe Hormigos
    Giuseppe Hormigos Oct 19, 2014
    is a Z18B
  • Drew Allan
    Drew Allan Jul 25, 2020
    Its a Taitron Part TZXJ18B RS Stock No. 818-4951
5 Related Answers
prijo_haman
SOURCE: boston soundware 5.1 subwoofer is clicking on and
I read on another forum is to turn your stereo level for the sub all the way to max then dial back the level on the sub to desired level.
Posted on Mar 03, 2012
rd2xpld
  • 107 Answers
SOURCE: hi there, I have a set of Boston Acoustic VR975
www.hometheaterforum.com /.../high-end-boston-acoustics-vr975-2-vr-mx-2-vrmc-1-for-sale
Try here
Posted on Feb 19, 2010
buffalonyman
buffalonyman
  • 1865 Answers
SOURCE: What kind of cables for Boston Speakers?
You want stranded wire, speaker wire, 14 - 12 gauge
Posted on Oct 07, 2009
Anonymous
SOURCE: static sound when red light blinks
It might be a loose connection. Do you obly get the crackling when the red light flickers?
Posted on Dec 29, 2008
Anonymous
SOURCE: hello, my boston acoustic TVee
mine is doing the same thing. have you found a fix for this?
Posted on Dec 26, 2010
My subwoofer just starting a clicking noise. what could it be?
You may have dislocated the voice coil. Repair shop may be needed.
Feb 19, 2015 | Boston Acoustics Audio Players & Recorders
How do i pair to a Boston Sound System
If your device requests a pairing code, enter the number 0 0 0 0.
Once paired, the Input Mode light will be solid blue for several seconds.
Sep 22, 2014 | Apple iPhone 5
Home subwoofer no sound
always 1 speaker per amp output!!! and between red and black only. You can send any signal into a subwoofer. Hi frequencies will be quiet but it's safe. switch a normal speaker for the sub and listen, you should hear a muffled sound. Look for the sub output on the amp... do you need to switch on the sub manually somewhere?
Sep 02, 2014 | Boston Acoustics Audio Players & Recorders
I have a low red light on my amp and no sound coming out of my sub, any help please
Check the wire connections from the amp to the sub. Connect them to any other speaker instead of your sub. If you hear sound the problem is your sub. If you do not the problem is that your amp is not supplying a sound signal to your sub.
Dec 20, 2013 | Boston Acoustics GT22 Car Audio Amplifier
Acoustic reaserch subwoofer dont have any sound
If this is a powered sub then it's most likely the internal amp inside it that has failed. It's more than likely the part that works the hardest on the board. IE the main amp semicoductor.
Dec 19, 2012 | Boston Acoustics Audio Players & Recorders
Red status light will not go off or change on Boston A TVee model 2 soundbar.
I am also having the same problem. It was working fine until we moved. Plugged it in at the new house and nothing but a red light. Sub is green though.
Jul 10, 2012 | Boston Acoustics TVee Model Two TV...
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Replaced the ZD3 on the Boston Acoustics Soundware xs 5.1 subwoofer with a 18 Volt-1 Watt Zener part number 1n4746a. and works like brand new.
May 27, 2012 | Boston Acoustics SoundWare XS 5.1 Speaker...
Hi there, i have a orion cobalt 2105xp 400. i have hooked all up, but very little bass. i have 1 10" boston acoustic sub. i noticed that the led is constant red, is it supposed to be green, crossover...
amp is in protect mode. check your wiring and make sure your sub is wired properly for ohms. dual 4 ohm in parallel = 2ohm. dual 4 in series is 8 ohms. dual 2 ohm parallel= 0.5 ohms and in series 4 ohms. check ground and power wires. make sure sub isnt blown. a blown sub WILL cause this on any amp.
Sep 10, 2011 | Orion Cobalt 2105 XP Car Audio Amplifier
Boston soundware 5.1 subwoofer is clicking on and off all the time
I dont have a solution, but Im having the same problem, and so is someone else:
http://www.avforums.com/forums/speakers/1205745-boston-acoustics-soundware-xs-5-1-review-6.html
Bad batch maybe? Lets get your input and maybe we'll get to the bottom of it.
Jul 10, 2011 | Boston Acoustics SoundWare XS 5.1 Speaker...
Boston Acoustics SoundWare XS 5.1 Speaker System Logo
1,651 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
