SOURCE: Kenmore Elite Refrigerator Whirring
Hi It sounds like the evaporator fan. It could be hitting some frost on the evaporator coil. Remove the rear panel inside the freezer section and see if something is in the fan blade or if frost is building up on the coils. If there is frost (more then just a thin film) you might be having a defrost issue.
please let me know what you find so I can assist you further.
Vic
SOURCE: refrigerator was making a 'Thump
Unplugging for an hour won't allow it to defrost if that is what the problem is.
Look inside the freezer at the back wall. Look for heavy accumulations of ice building on the cooling coil, which is behind the back wall panel. You may have to look in the louvers or past where the evap fan is located.
Once we know if there is heavy frost or ice there, we'll have a better idea how to resolve. Is there any warranty on this refrigerator that you know of, besides the 5 year compressor warranty?
SOURCE: Gr Side-by-side refrigerator freezer makes noise when door close
It is possible that the hinges of your freezer has moved and shifted the alignment. So first of all use a WD40 cleaner to spray into the hinges and the areas around it. Now move the hinges violently for some time and check if has lessened. If so repeat the spraying. See if here is dirt accumulated along the hinges if the door is not moving parallel just push the end up a little . You must be able to get the hinge to shut properly by this correction. Hope you try . Good day
SOURCE: I have a kenmore elite
Hi and welcome to FixYa. I am Kelly.
The humming noise your hearing is the evaporator fan blades striking the ice build up on the evaporator. The fact that you have ice build up is a sure sign your refrigerator is not defrosting.
The door switch controls power to the evaporator fan.
I am going to use this model number 106.57071791 as a parts reference that MAY be different from your actual model but it is close. This model is a mechanical control refrigerator. You may have the electronic control version.
Take a look at item 6 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657071791/0582/0165000/P8100197/00012?blt=06&prst=&shdMod=
It will be located in the top left of center & front of your fresh food compartment. It will be circular and will have 2 tabs on it with an incline so that if you were to rotate the tabs with something flat it would only turn ONE direction.
Either use your finger nail or something flat to SLOWLY rotate that until you hear an audible click. (Everyting stops but the lights) This is initiating an automatic defrost cycle. After about an hour come back and check to see if your refrigerator has re-started. If it has not restarted there is definately a problem with the automtic defrost circuit. That can be the timer (listed above), The defrost element under the evaporator, the Bi-metal thermostat on the evaporator or wiring.
All parts can be found via this link / section
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657071791/0582/0165000?pathTaken=
If none of the links work go to http://www.searspartsdirect.com and enter your model number where it says find it fast and choose model search.
I guessed at the model number so if this does not resemble your refrigerator or you have the electonic control board type refrigerator please respond with your model number.
Thanks for choosing FixYa,
Kelly
I've heard similar refrigerator noises like yours before. Sounds like the evaporator fan motor, located in the freezer and runs only when the door is closed, is being obstructed, possibly by ice, possibly by some wiring or even a food item. You could have a defrost problem, but you dont mention any refrigerator or freezer temperature problem, so that is likely not it. It is also possible the evaporator fan motor itself is out of balance. If you remove the back wall of the freezer, you will be able to see if there is something obstructing the fan blade, if the motor or shaft is out of balance, when you close the door light switch, check the balance of the shaft, it should not have any wobble at all, in fact, if the fan blade is not attached, you should not be able to tell by looking at the motor shaft if the motor is running or not. Also, just happened to think, if one of the fan blades is even partially broken off, that will cause the motor to be out of balance. But if one of these blades is broken, it was broken by something else, either ice or something, and you may have to find the cause of that, otherwise it may happen again.
