Question about BenQ Office Equipment & Supplies
Delete files from the internal memory
Hi, I need to delete the files from the internal memory of a BenQ gp10 projector. I only have access to a macbook and when i delete the files in the finder they remain on the projector but within a trash folder. If you could suggest a workaround to wiping the internal memory that'd be brill! Thanks.
Posted by Rachael guiver on
  • 1 more comment
  • Rachael guiver
    Rachael guiver Mar 14, 2014
    Hi, thanks for your quick response. I tried that and the files were deleted from the Finder window, and I emptied the trash.
  • Rachael guiver
    However when I go onto the projectors internal memory they are still there in a folder called trash.
  • Rachael guiver
    I just can't see them from my macbook.
rrreuter
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Instead of deleting them from your gp10, try moving them off the gp10 to your MacBook. Then delete them from the MacBook.
Posted on Mar 14, 2014
Testimonial: "Thanks for your help, it didn't work though. Completely puzzled now."
  • rrreuter Mar 17, 2014
    Rachael: The .Trash is a byproduct of the MAC OS. Think of it like the recycle folder on a Windows PC. The only other suggestion I can think of is get a friend/family member to hook up a Windows based PC and delete the file of the BenQ internal drive that way. Then clear the recycle trash can folder.
4 Related Answers
Anonymous
SOURCE: decode benq mp720p password
Hi benq mp720p projector.
coded number: 22134-13770-6789-8385 help pasword
[email protected]
Posted on Sep 02, 2011
Anonymous
  • 104 Answers
SOURCE: projector shutdown
your air filter of your projector is dirty, try cleaning it. tnx
Posted on Jan 30, 2008
Computer Links
  • 2386 Answers
SOURCE: hi , i have the same problem, i lost password on
try 7040
good luck
thanks
Posted on Feb 24, 2011
gopakumarg43
  • 76584 Answers
SOURCE: Hi, Benq MP610 projector is in password mode. The
Hello
Here you have got the coded password. There is no other way than contact the Local BenQ service center to decode this coded sequence. OK.
Posted on Nov 14, 2011
How to delete if internal memory card full
Hi
You can either download photo, data files to a SD card, another device (computer) or simply delete unwanted data by using the file brower. Locate, the unwanted files in storage, camera, or certain apps folders, & delete files. Don't delete any file in system folder. Hope this helps. Regards Bob from OZ
Jul 27, 2014 | tmax White 8GB 9" Android 4.2 1.6 GHz,...
Benq GP10
rotate image features not avalable in BenQ gp 10
Feb 03, 2014 | BenQ Office Equipment & Supplies
How do I delete pictures from the internal memory of the Polaroid XSA-10169s digital photo frame?
From the slideshow, press the Menu button to access the thumbnail view. Highlight the photo you wish to delete. Press and hold the Menu button for two seconds; the Delete File option will appear. Press the Ok button to delete. Press the Ok button again to confirm. There appears to be no Delete All option.
May 07, 2011 | Polaroid Cameras
I'm trying to find out how to delete all the pix on my camera at once. anyone know how?
hi, if you connect the camera to your computer and open the folders in file veiw you should be able to simple drag around them and press delete
Feb 11, 2010 | Olympus FE210 7.1 MP Digital Camera
Internal memory is full,I have erased all
Take out memory card from camera, format internal memory to delete all pictures at once or delete them one by one.
Once memory card is inserted in camera, internal memory is no longer available to store/ delete pictures so remove memory card from camera to get access to internal memory.
Nov 06, 2009 | Kodak EasyShare C743 Digital Camera
Trying to move photos from internal storage to computer
Do you use your phone to browse the internet? if so, go to internet explorer -> options -> memory. and let it delete all temporary internet files. That should free a lot of internal storage. Turning your phone off and on again can also help to delete temporary files to make room in your storage memory.
Jun 19, 2009 | HTC Touch Diamond Smartphone
How do I delete files from the internal memory?
When that happened with me, I plugged it in my computer and just deleted it there. I think that worked. Or that was why I switched the whole thing to "mass storage device" and left it that way. It was easier.
Mar 07, 2009 | iRiver E100 Digital Media Player
Deleting files from HTC Touch Diamond
go to file explorer and select the files u want to delete and then try to delete them see what happens
u can contact for more help
regards
Feb 28, 2009 | HTC Touch Diamond Smartphone
Can't install mp610 printer
The drivers for the printers you deleted may not have been deleted from the system print server.
Play it safe and make sure you have source files for re-installing any print drivers you delete.
From the "Printers and Faxes" window, select File/Print Server.
Select the DRIVERS tab, delete any drivers referring to the Canon printer.
Reboot or alternatively, use the services.msc to stop and restart the print spooler service. Now try to install your new drivers.
Nov 20, 2007 | BenQ MP610 Multimedia Projector
Can I delete the PIF frames and sound files stored in the camera's internal memory?
Yes. There are two ways to delete the PIF frames and sound files from the camera: * Connect the camera to a computer and drag the EPUDL folder and EPSOUND folder to the recycle bin or trash can on your computer. * Format the camera’s internal memory. Note: If you plan to restore the sound files to the camera’s internal memory, save a backup copy of the EPSOUND folder before you delete the folder.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Michael Thomas
Michael Thomas
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
