SOURCE: Motorola Talkabout T5100
I think you have to remove the courtesy beep option from radio, this is also call Roger beep.
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
SOURCE: motorola t5720 walkie talkie not transmitting or receiving
To answer your questions: the airport xray should not have harmed them, and there is no reset button.
If you are using the radios with the rechargeable battery pack, it most likely needs replaced. They have a life expectancy of 12-18 months. Here is a link to the Motorola store: http://www.store.motorola.com/mot/en/US/adirect/motorola;jsessionid=B7997F21F6A409F029D6DEC2CB194ADB.mot2?cmd=catDisplayStyle&entryPoint=adirect&catKey=601560&messageType=catDisplayStyle Clean your battery contacts both in the radio and on the battery with a pencil eraser.
There is also a chance the radios are not programmed correctly. Be certain the frequency, interference code eliminator and the Qt filter (if any) are set identical to one another. You indicate you have a manual, I will insert a link here for those who do not, who might read this: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Lastly, you may simply have one radio which has failed. It is not likely both would fail at the same time, short of battery issues. The three items listed above are suspect: batteries, programming or one has failed.
Best regards.
SOURCE: Can Receive but not Transmit
1) Double check your interference code eliminator and the Qt filter. Make certain they are all set identical.
2) If you are still having trouble, shut off the Qt filter.
3) Then if you still have trouble shut off the code. (Off is sometimes "zero" or "n" for no.)
4) If the above steps do not help you have either a defective radio, or a bad battery. Switch the batteries out of the working units to the non-working and see if the problem switches to the other units. If so, replace the battery packs. (Note: it takes more battery power to transmit, so the problem would first show up in the transmit area.)
Best regards.
Testimonial: "Response from this site is almost immediate! Will try it out & respond asap ... although I must say I dont understand those techie terms:{ TQ anyway!"
SOURCE: I'm searching for a User Manual Walkie Talkie T8550R Camo
I think you'll think this is fantastic: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
