Question about Konica Minolta bizhub C250 All-In-One Laser Printer
I send a print but pages aqre blank
I send i text for print but pages are coming blank
Posted by nikogr on
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,958 Answers
Does this happen when copying? Can you print internal copier form meter count etc.?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 29, 2015
  • sevon smith
    sevon smith Jun 20, 2018
    i am having the same problem even if i am coping it comes out blank
Why won't it print test page?
If the test page placed face down on the glass does not contain text, you will get blank copies.
Jan 08, 2016 | Office Equipment & Supplies
No print only a blank page comes out
Wrong printer drivers for your computer or else they did not install properly. Also blank page may mean you are out of ink/toner.
Aug 19, 2014 | Office Equipment & Supplies
Pages come out of printer blank
It’s making te noise of printing or just get the paper and got it out fast ? If goes straight out is the driver if goes line by line and is blank the cartridges are dryed or the injector are clogged with old ink. Time to buy a new one or send it to maintenance
Nov 10, 2017 | Kodak EASYSHARE 5100 All-In-One Printer
Printing jobs are coming out with the text off the page
Some blank paragraphs may have spilled onto the last page. To view paragraph marks (paragraph mark: The nonprinting symbol that Microsoft Word inserts when you press ENTER to end a paragraph. The paragraph mark stores the formatting you apply to the paragraph.), click Show/Hide on the Standard toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.). If you see paragraph marks without text on the last page of your document, delete them. Then click Print Preview on the Standard toolbar to view the document as it will be printed and verify that there is no longer a blank page at the end of your document
Sep 26, 2011 | HP OfficeJet Pro K8600 Printer
Cannot print emailed air confirmation page -- when I select print, the only thing printed is the top line, e.g., United airlines, but not the reservation information. After that first one line, only...
Copy the text into the NOTEPAD application, to remove all text-formatting & text-colouring, e.g., "white" text over a "black" background will become "black" text over a "plain" background.
May 07, 2010 | HP Photosmart C4580 All-in-One - InkJet...
WHY DO I GET A BLANK PAGE AFTER EACH FAX?
The fax machine that is sending you the fax may be also sending a confirmation page that is not needed or compatible with your machine.
I have an older machine that prints a confirmation page after each fax. People on the other end sometimes receive a blank page after each fax that I send them while my machine prints a mostly blank page with only a single line of text at the top with the date and time.
Feb 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I get a blank page when printing a text only document
1,check the correct driver installed or not
2,select default as A4,plain
Oct 25, 2009 | fedora Linux Operating System
The printer is issuing blank sheets - every other sheet being dispensed by printer is blank - i.e. without printed data
This could happen if the text you are sending to the printer spills over slightly onto a new page. To test for this, press Ctrl-P and select "Current Page." This will insure that only one page is being sent.
Aug 12, 2009 | Lexmark Office Equipment & Supplies
Samsung printer ML-1450. When the first page is being printed, paper stop at half-way. Open the lid and close it again, it finishes printing the first page and spills out a blank page as well. This problem...
my printer not work in win xp and also in dos i send data to printer but first line of first page come true after that print another text that havent any meaning what can i do?
Oct 14, 2008 | Office Equipment & Supplies
Wont print text
Clean your black printheads tobyss. Remove cartridges. Using cotton buds and proper cleaning solution, clean where the cartridges sit in, until no colour comes away. Press a babywipe (unscented) firmly on bottom of cartridge where ink comes out. Replace cartridges. Print again. Run printers own cleaning solutions too.
Aug 14, 2007 | Lexmark X4270 All-In-One InkJet Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
180 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
