Televison & Video Logo
A
Anonymous Posted on Mar 14, 2014
Where to connect the cable - Mitsubishi VS-5043 50" Rear Projection Television
How do I set up a cable box for the television please?
Follow the steps below to connect your cable box to your TV using an HDMI cable:
  1. Turn off your TV and cable box.
  2. Make sure the wall cable connects to the cable box.
  3. Connect the HDMI cable to the cable box port.
  4. Attach the cable's other end to the HDMI port on the back of your TV.
Jan 14, 2024
How To Connect Your TV To a Cable Box (2024 Guide)
Where to buy a drum connecting cable for a drum drain machine
I guess you're talking about the cable that first connects to the drum and then to the auger's main cable. You really don't need the connecting cable. Just connect the main auger's cable to the drum and you might lose 12" of cable. If you still want a connecting cable, then buy the Weld On Cable Ends on Ebay and a cable. If you have a Drain Cleaner dealer near you, they will have cables and probably a 3 foot piece you can use as your connecting cable.
Oct 07, 2014 • Plumbing
Connecting VCR ,cable box, TV
First connect the cable box to TV using HD-cable (if connection available) or component cable (three leads) observing the colors. Connect cable box to VCR with an S-video cable or SCART if you have an S-video out scart. Connect VCR to TV with another S-video cable (round connectors) or with a scart to an S-video in scart connection. If you are in the US, the scart connections don't apply.
HOW DO YOU CONNECT CABLE BOX
Connect a Cable Box to a Receiver:
1 Gather all your tools, parts and cables together before you start the connection process. Chances are you will need to connect several items at the same time, including your TV, audio system and TV cable receiver. Your cable box manual is likely to include a diagram of how to make the appropriate connections, so it's important that you read it before attempting any links.
2 Connect the output of the cable box to the input of the receiver. If you are connecting an audio system as well, make sure the audio output cables go directly into the receiver and, from there, to the cable box. Avoid direct connections; instead, go through the receiver for all secondary connections.
3 Select the correct jacks for sound and video. A newer model of receiver should offer several options, including analog TV out and DTV out. It should also offer an S-video and a service port. Depending on the type of cable box you use, one or more of the same jacks will be available there, too. When connecting both systems, make sure cables go between similar outputs.
4 Use an S-video connection cable to link your TV with your cable box. S-video connection cables allow you to preserve good quality in both image and audio. Most cable boxes come with S-video connection cables, but you can get them at any electronics store. Once you have them, simply connect both ends to the right output. It'll be easy to identify, because it's usually the only round one available.
5 Plug the TV, cable box and receiver into an electrical outlet to make sure everything is working properly. If you are getting static or interference, you may need to tighten the connections or change the cables.
1helpful
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
I'm having trouble connecting my emachine to a cable modem.
Turn off the computer before you begin making connections. Make sure the cable modem is up and running with your service before you attempt to make the computer connection.
  • 2 Connect the coaxial cable from the wall outlet into the back of the cable modem where it is marked "Cable" and has the male coaxial connection. Use an extension coaxial cable if necessary to reach the modem.
  • 3 Connect the CAT 5 networking cable from the cable modem where it is marked "PC" (or something similar) and connect the other end into the back of your computer where the networking card is. These connections are RJ-45 connections that look like oversized telephone jacks. If you also have telephone service through your cable provider, you will want to connect the telephone line into the port on the back of the cable modem marked "Telephone."
  • 4 Connect the power cord into the back of the cable modem and plug it into a power strip with power surge protection. The modem should power on by itself once it is plugged in. It will cycle through a power on self test and then make the connection to your cable Internet provider. Once the lights indicating power and cable are green, you are ready for Step 5. It could take several minutes for the modem to connect to your service provider.
  • 5 Turn on the computer and test out your Internet connection. Should your computer still have a problem connecting to the web you may need to reset your cable modem. You will find a small recessed button the size of the head of a ballpoint pen either on the back or front of the modem. This button will be marked "Reset." Pushing it once will allow the modem to reboot and reset all its connections. Turn off the computer before resetting the modem to allow the computer to flush all the networking connections out of its memory as well.
  • If the power goes out and your connection is not restored when it comes back on, always reboot the devices in this order: cable modem first, computer second. Keep the cable modem where it can get proper ventilation. Call your cable Internet provider if you get frequent interruptions to your cable Internet service and rebooting the modem does not solve the problem.
    I want to connect to a TV that;s already connected to a cable tv box
    What do you mean? Do you want to connect or add another tv to that cable box?
    Like two TVs connected to one cable box. If so, on the back of the cable box you have three different ways to connect a tv from, through AV cable, component cables and coaxial cable.
    If the main tv is connected by coaxial, the second tv can be connected thru AV or Component cables..
    Hope this helps.
    How do I hook up a VCR? There is only a portal for the cabel on the back. mpartridge
    You will need to have a VCR with a cable connection on it. You will need to remove the cable connection(if connected) on the TV and connect it to the "cable in" connection on the VCR. Then the coaxiel cable will connect from the "cable out" connection to the cable connection on the television. You will then need to turn the channel on the TV either to channel 3 or 4. Then turn on the VCR and you should be able to watch a tape on the VCR. If your VCR does not have a cable connection on it then you will need to buy an adapter that turns the cable connector into RCA style jacks.
    1helpful
    I need to know how to run my ps3 thru the optical wire to my hdtv
    Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
    You can connect your Playstation 3 to your TV in three different methods:
    1. Connecting with an AV cable
    2. Connecting with an HDMI cable
    3. Connecting with an Optical Cable
    Connecting with an AV Cable:
    1. You are supplied with a Composite AV cable which would typically look like the below image
    2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
    3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
    Connecting with an HDMI Cable:
    HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
    1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
    2. Connect the other end to the socket on the back of your TV which says HDMI IN.
    Connecting with an Optical cable:
    You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
    1. Connect one end of the optical cable to "Audio Out" socket on the console
    2. Connect the other end to the audio receiver.
    Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
    The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
