Question about Haier HL32R 32 in. LCD TV
POWER SUPPLY schema psa218-417-r
What are the values for capacitors C503 and C507
Posted by Murad Alandar on
1 Related Answer
gopakumarg43
  • 76823 Answers
SOURCE: Hi good morning I need your help please , I have 32" lcd tv two capacitors from the power supply blown up C503 and C507 board Model PSA218-417-R I would appreciate if you write down their values . Th
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 14, 2014
How do I identify a bad capacitor on a Samsung LN55C610N1F power supply board?
you can tell by the top of them,when there bad they bulge ( as if there going to pop )
2answers
How can i repair str z2062 power supply of my hp m1005 mfp laser printer ?
First of all; it is DANGEROUS to fix a power supply if you don't know what you are doing. Thus; don't even think about to open power supply tower, if you are not qualified enough.
If you are a qualified person, you can go on with below steps by taking risk on your own.
You must discharge biggest capacitors in order to avoid any fatal electrical shock. Even it is disconnected from electricity plug, power supply may keep high voltage in it for long time. Once you discharge big capacitors; you may diassemble power supply tower. At your question you mentioned about burned power supply which makes it a little bit easier. (I assume you discharged big capacitors) Once you open psu tower; do visual inspection on each capacitor. If there is a burned area start with it. Remove blowed capacitors and replace them with same valued new capacitors. If you can't see the values on blowed capacitors; you need to find board diagram of your psu. Otherwise you can't find suitable one to replace. Besides; check form of other capacitors. If there is a change on any capacitor's form, replace them too. The best way to find out dead capacitors is using capacitor testers. If problem caused by another type item; its not easy to find it as finding bad capacitors.
2answers
I need a schematic for my samsung tv power ciruit board BN44-00438B trying to find the value of a little blue capacitor that fried up.the capacitor is placed on CP820..
I dont have the schematic for this board but I hope this info work. The value of the capacitor (CP820) is 221k 1kv. Heres a picture and a conversion chart. You can see the conversion code from pf to mf.
http://tubeamplifierparts.com/handy-amp-info/capacitor-code-chart.html
Oct 18, 2013 • Cell Phones
2answers
Big shadow on tv model ld4088
You can download the manual from here.
My tv is not powering up, but the power button keep flishing green?
Its a faulty power supply.There's a leak capacitor that cause of low voltage output of the power supply.The leak capacitor can identify through visual checking.The leak capacitor have bulging tops.Open the cover and find the power supply located at the upper right and you can see the bulging tops of capacitor.Replace the same value of capacitor.
3helpful
My power light keeps blinking and the tv powers on for about 2 seconds then it powers back off. What would be the problem
That problem is commonly happen to LCD television.The cause of the problem is abnormal supply voltage of the television.The problem is the power supply.There's a leak capacitor in the power supply that may cause of abnormal output voltage supply.You can identify the leak capacitor through visual checking if you don't know how to use the capacitor tester to find the leak capacitor.First thing to do is,open the back cover of the TV and look the power supply,it is located at upper right parts of the TV.remove the cover of the power supply and you can see the leak capacitor.It has a rounded shape at the top compare to flated top shape of good capaitor.It also sometimes have moise at the top.So try to replace all leak capacitor with new capacitor with same value.Example of capacitor value is 330mf/35v. Make sure that there's no short circuit when you soldering the PCB board of the power supply.The tools you can use is, Soldering iron,soldering lead,soldering pump,diagonal cutter flier and philip screw.This procedure can be applied if you want to repair your television at your self. So if you don't want to repair just call a technician.But the the problem is in the power supply.Hope it will help you..Thank you..
Automatic return on stand-by mood when power is push on
The problem is the power supply you have a weak power supply.Try to check the power supply if their is a swollen capacitor or leaky capacitor, you will notice that their is a oil mark that spread in the pcb then replace the capacitor with the same value and observed the polarity of the capacitor.
SCHEMA POWER SUPPLY 243891
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
2answers
White lines on picture
There aren't any adjustments to be done for this issue. The only way to fix it will be to replace a low capacitance electrolitic capacitor(s) in the vertical section of the TV. The capacitor value may be below 100uF depending on the brand of TV you have.
Hope this helps.
Haier HL32R 32 in. LCD TV Logo
Top Haier Televison & Video Experts
Kolbrun...
Paul Bade
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
