Question about Zassenhaus Coffee Makers & Espresso Machines
Disassembling Zassenhaus Havanna
I find old Zassenhaus Havanna. I would like to clean it, it is a little bit rusty. Is complete disassembling possible? I unbolted screws but inside part seems to be fixed somewhere...
Posted by Marie Juptner on
4 Related Answers
Anonymous
SOURCE: Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Posted on May 03, 2009
cmccune04
Clayton McCune
  • 214 Answers
SOURCE: How to disassemble a Keurig B60?
I can't tell you that but I can point you to replacement parts dealer. The best of luck to you, Hope it helps:)
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Posted on Apr 18, 2010
tgmusicgirl
Lisa
  • 101 Answers
Not sure why you want to get the top off first :(
start with the black wrap around shroud first...
Take the metal bottom plate off first... then you can see the way the wrap around plastic shroud slides off... however... you have a hose and water tank plate base assembly in the way... need to cut the ty-raps off the hoses... they are smaller then 4" Panduit ty-raps... so go get a few... only 2 or three.
Once toy get that water base unit away... watch those leds...
you start from the right side of the shroud and pull the shroud down... exposing a phillips screw on top... get needle nose pliers to start a bite in it.
the shroud has self locking plastic teeth molded on the shroud and the silver top...once snalled onto place, they are a bytch to get off.
I wrote instructions to do this on another question... work carefully... use a stiff pointed piece of plastic shaped like a chisel... metal will chew up the plastic cover and shroud.
there are 2 screws... one on the left one... one on the right... start right side first
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Posted on May 17, 2010
Darryn O'Neill
  • 115 Answers
SOURCE: Im having trouble disassembling my Z7, I believe
Hi. There are screws in the back. Then you'll have to take the top off. There usually a couple in the top. Top lifts and moves back. Empty out the beans before you remove the top. Some machines have screws on the front behind the bottom waste draw in the corners. the side panels just slide up or back by placing the palm of your hand firmly against the panel and give a quick **** in the direction you wont to go. Easy when you know how. Lol. All machines are different so just be paitent with it. I get such satisfaction when I work on Jura, so have fun. dazza
Posted on Oct 15, 2011
Fein fmm250q not oscillating.. How do I disassemble the head?
Special be carefull with the 4 torx screws if you decide to disassemble the head because all the material of this machine is very soft before you know its broken its also not a expensive Fein model but a nice machine for that price . take a hand screwdriver with direct the right size to feel if its correct fit because its to late if a screw breaks. yes its having very soft material screws, the head cannot have a disassembling its a complete part and if that is complete but all by all decide if you think its worth to replace beware of the price , the price is marketing technically adjusted for this machine and expensive and not made to dissasemble in a bench vise you can all things try to disassemble but re-assembling with new spare parts is not deliverable. only complete . 1 little bearing gives the little eccentric rash on the head , i have i all the time i repaire tools not one time that a head of this tool was defect if you can move the lever free and smootly you can solvent clean and after that lubricate it again but re connect the bearing fronttop machine between the space in the lever set the head in a bench vise fixated that the lever is correct in the center position , and then mount the machine slowly on the head again and if its run mount a attachment or blade and control it again .
Jun 09, 2015 | Fein Vacuums
Last year I got this device and after 1 & half year my device is not working & showing check gps antenna. Can u please give me a solution Javaid
Probably the gps antenna is not working due to rusty (water inside it). Check the antenna disassembling it. Third part antenna for the NT1 is not available due to proprietary connector so you must buy a (expensive) genuine new one from JVC. Sometimes it's possible repair the old one.
Apr 21, 2011 | JVC KW-NT1 Car GPS Receiver
My iphone 4 does not ring!
Hi,What causes phones not to ring out is when the ringer that makes you hear a tone when someone calls is damaged and does not work properly again.
The ringer is located inside the phone.You can get access into the phone by disassembling the phone with a phone screw. It a little bit technical when unscrewing the phone.Just be careful not to damage the phone.
How to disassemble the phone.
You can use the below link to disassemble the phone
jorymon.com/tag/unscrewing-iphone-3gs/
Note:if you can't loose the phone, in other not to cause damage to the phone,please contact a skill full personnel for assistance.Thanks.
Thanks for using fixya........
Before you replace it,you can also clean up the ringer ,there might be dirt stopping it from working properly.
Have a nice day.
Jan 10, 2011 | Apple iPhone 3GS Black (16 GB)
To know how to disassemble my acer aspire one 532h-2588 net book, it keeps overheating and shutting down,so i wish to disassemble it to clean out all the dust in it. please help.
Here's the complete disassembling procedure...
http://erkinson.altervista.org/acer-aspire-one-532h-aggiornare-ramhdwifi-smontare-lcd/
google translate it
Jul 07, 2010 | Acer Computers & Internet
How can I clean the camera's CCD
I strongly advise against disassembling your camera. Unless you really know what you're doing and have the proper tools and realignment equipment, you will surely ruin your camera. What makes you think the sensor needs cleaning?
Jul 06, 2010 | Canon PowerShot G9 Digital Camera
When I try to play a Blue Ray DVD movie I get the
Use a q tip with a little bit (not dripping) of rubbing alcohol. Eject the tray,unplug, look for laser,you may have to do a little bit of disassembling,but have no fear if you have a digital camera at hand. Use the q tip and gently spin it between your fingers and lightly press against the laser lens. Let the lens dry and look for streaking,if it streaks,youre using too much alcohol. After cleaning,test with an audio cd,then regular dvd,then blu ray. If it works awesome,if it doesn't then the laser is most likely burned out.
Nov 01, 2009 | Sony Televison & Video
Shimano Dura Ace Brake lever chatter
A few suggestions:
Lube/replace your cables and housings. If your housings are getting rusty on the inside, it will prevent the tension in the spring of the calipers from returning the brake levers to "home" position. Also, dura-ace levers have an internal return spring that is prone to breaking or coming off its peg (this can't be repaired without disassembling the lever).
Make sure your calipers are clean and move freely, and have sufficient spring tension to return to "home" position.
Be careful not to get lubricant on the braking surfaces, obviously.
As an experiment, remove the wheel and pinch the calipers together with your hands. Then, check to see how loose the brake lever is.
Mar 26, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Cleaning behind front screen.
Sorry my friend. You and I both know the answer to this. A complete disassembly and cleaning is needed. A fire hazard is a very serious event waiting to happen. Take care of this ASAP!
Ray
Nov 06, 2008 | Holmes Products HQH307 Compact Heater
Coffee Makers & Espresso Machines Logo
96 people viewed this question
Top Zassenhaus Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Zassenhaus Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
