Question about Hotpoint Refrigerators
I have a 1999 gmc yukon which recently cut off on me while I was driving and would not start back up but the next day I tried it again and it started and cut off in about 2-3 seconds so i was thinking it is the fuel pump but I decided to try and change the relay when repressurizig the fuel system after replacing the relay when I turn the ignition on I heard a sound every time I turned the ignition on what does this mean?
Posted by Anthony Pope on
Marvin
    Top Expert:
  • Hotpoint Master
  • 85,239 Answers
First run a fault code test at the diagnostic link under the dash on drivers side and see if any fault codes are in memory, if nothing shows then test the fuel pressure, the test port is in the fuel supply pipe that sits over the fuel injectors on the top of the engine, looks like a large tire valve. You will need a special tool, borrow one from a local auto parts store like Autozone.
Posted on Jun 26, 2017
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
Anonymous
SOURCE: Samsung model SR-L38NMB refrigerator
that problem very likely is the control board. there is another brand of fridge in S.AFRICA THAT DOES THE EXACT THING OF WHICH THE BOARD HAS TO BE CHANGED.
Posted on Jul 25, 2007
MARK FISHER
  • 87 Answers
SOURCE: GSH22JSRE SS not cooling
I would strongly advise seeking a competent fridge guy. If it is the compressor (which sounds like a distinct possibility) they should be able to identify it very quickly. They would then be able to give you a cost on replacement. Alternatively you could try throwing it back at where you got it from and see if there is an extended parts only warranty. Some manufacturers now have three or even five years warranty on major components (ie compressors). Although there is no guarantee of this, its always worth a try, you might get someone sympathetic to your plight, due to the young age of the cabinet. Hope this is of some if not limited use.
Posted on Sep 11, 2007
fmauka
  • 17 Answers
SOURCE: Not Cooling and has burning smell
If you are looking for help, one must explain the problem in detail, described properly, for one one the internet to review. For myself, a would require more details of your refrig, to properly explain a resolution. Otherwise a general answer is not worth much. If you have the fully electronic temperature controlled unit, then the components can be easily chedked in 5 minutes, by the on-board service diagnostic computer. One needs to know the general operating knowledge fo the refrig, which is naturally available, since you operated it for some years. Anyway, a layman can check it out by doing what is natural. Since the refrig defrosted, it has shut down. Four years is too short for genral compressor defects. Put the power plug in and check for operating sounds. Just a few seconds. You mentioned smell (outside or inside), ket a paper tube, like a paper towel center, and sniff the evaporator motor, then the condenser motor. I will recheck later, and see if you want to continue, this troubleshooting. Regards fmauka
Posted on Sep 22, 2007
Anonymous
  • 3 Answers
SOURCE: wont start, no faults on ecu,keeps flooding,
Sounds like the old nikasil problem.Remove all of the spark plugs and squirt oil down each bore,replace plugs and she should fire up.
Posted on Oct 12, 2008
2014 GMC Yukon XL having hard time trying to get it to start
possible lose connection to battery or ground on the body.Grab and twist every ground wire you see .tight and clean oxydaition.
Mar 24, 2014 | GMC Yukon XL Cars & Trucks
My 1999 gmc yukon was running fine then all of sudden wont go into gear at all if you accelerate it justs revs up and wont go
It's an obvious transmission problem, If you throttle down and it Does NOT move that's the problem
Apr 19, 2013 | 1999 GMC Yukon
1999 GMC Yukon turns over but will not start, there is a clicking sound, the check engine light came on the last time it started .
check code first get clue what next,could be crankshaft sensor,battery and battery connection.
Feb 28, 2013 | 1999 GMC Yukon
I have a 1999 yukon it cranks up and runs but just shuts off while driving but cranks back up and sometimes i can drive it all day no problem next morning shuts off on me twice but starts again and I can...
That could be a number of things. A mechanic would have to keep the vehicle until the problem came up again to diagnose it.
But when I would have a vehicle that did what you described, one of the more common things I have found is that the vehicle had an alarm and the alarm was faulty. The alarm would not even have to be used. Just being intergrated into the system was enough for it to cause this type of issue.
Is the service engine light on? If so, take it to an auto part store and most will hook up a code reader for free.
Also may not hurt to have the ignition module tested. Around here, Auto Zones have a machine that does it. Its a free service they provide.
Oct 11, 2011 | 1999 GMC Yukon
My 2007 GMC Yukon will not start in cold weather. When I turn the key over the lights/dash controls come on, but the engine does not turn over at all. Nothing. Put a new battery in and still does it. ...
My 2007 GMC Yukon will not start in cold weather. When I turn the key over the lights/dash controls come on, but the engine does not turn over at all. Nothing. Put a new battery in and still does it. It is a random occurance. Would not start for two days this week so I had it towed to the dealership and the next morning it starts without the service dept doing anything??? Bring it home and two days later it does it again??? Any ideas?
Dec 14, 2010 | 2007 GMC Yukon
I have a 1999 gmc yukon and as i was driving it just started to back fire can u please tell me what i can do resolve this problm..i have been told the distributor
That would be the cheapest thing to check first. I'd check and see if the catalytic converter is trying to clog up.
Dec 07, 2010 | 1999 GMC Yukon
My 1999 yukon wont start i changed master air flow
Fuel pumps are real common to go out on those vehicles
Mar 15, 2010 | 1999 GMC Yukon
Refrigerators Logo
27 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
