I've try to connect but still fail....my step - XP service pack 2 - enable fast swicthing login - only do the crossing LAN (pc to thinPC) - already from bootsrv appears anyting what can i do again? plis help
SOURCE: NComputing connected to existing Lan network
If your existing LAN has DHCP assigned IP addresses, you will be good to go. If you have statically assigned IP addresses, you will need to enter them in manually into the device. Their website has a very good instructional video on the procedures to hook up the devices. It will work with standard cat5,cat5E, or cat6 wiring.
Testimonial: "Good and quick response."
SOURCE: i have config the ncomputing
Hi Jerod - we'd like to get some more info from you on your specific configuration to narrow this down. But, it's likely an issue specific to the T110 (quick way to isolate is to run 2003 Server in a VM on the same machine to see if you still have the issue). Please contact us at http://www.ncomputing.com/techsupport (online or phone support) and we can help you with this.
NComputing Tech Support
SOURCE: Dear Mr. , I have VMware
Hello Rana,
Please recheck which model number you are working with, since what you are describing sounds like the L300 and not the L230. If it is the L300, then you may have initiated a firmware update from the console or from within the device. We'd be happy to walk you through this -- please contact us online or by phone by going to: http://www.ncomputing.com/techsupport
