Nokia 6350 Cell Phone Logo
Question about Nokia 6350 Cell Phone
No signal and emergency calls only messae?????
Why does my phone go into emergency talk only mode
bad signal, damaged phone internal arial but more than likely a blackspot for mobile signals.
Happy Xmas
2helpful
3answers
My phone screen is saying emergency calls only
Emergency calls only usually means the company has cut off your service, usually for non-payment. If it was another problem, like no signal, you wouldn't be able to even make emergency calls. Call your provider.
How to get a boost max phone out of emergency call mode
EMERGENCY CALLS
Emergency calls can be made in all device conditions as long as there is any
available network signal. From locked screen conditions press the Emergency
Call button to open the dialler, then dial 000 and press the handset icon to
make the call. In all other conditions press the Home key to return to the
home screen then press the handset icon to open the dialler. Enter the
Emergency number (000 or 112) and press the handset icon to make the call.
Aug 13, 2014 • Cell Phones
Emergency call
Check your sim card, might be faulty. It only default to emergency calls if it doesn't pick up your network signal.
Say's "call emergency only " for out going calls. Won't let me call out.
This means you're either out of signal or you've been cut off by your operator. Sometimes when your phone has no signal it can link with passing satellites, and by law, they have to allow you to use their transceiver but only for Emergency Services (999). This is why you have that message. OR You have been cut off and can only use the phone in case of emergency, call your operator and find out which one it is! :)
2answers
"emergency calls only"
Try resetting the phone. If that doesn't work, show it to a cell phone repair store. It maybe an issue with the IC that regulate the Cell phone signal.
1helpful
2answers
My motorola is showing, no srevice and emergency calls only. what is the sultion of this problems
hi, this is not an issue actually.
when your mobile's antennae does not recieve teh signal from the tower, you see this message. if you are just far from the signal, you'll see the emergency only, now you can call the emergency number 112 only,
when you are even not in the reach of emergency signal, it displays No Service.
you can use the Emergency signal when you are in need, you have to call 112 and an agents picks your call and helps you regarding police, fire, or you can ask them to inform some matter to others in urgency..
Narendra Tirunahari
My Sci phone 68i will not pick up a signal.
If you are trying to dial in only one place and it is reading emergency calls only that means you are not getting signal. Mine stays on emergency calls only while in the house using a T-mobile sim card. I don't get very good signal here. Try it in other places and see if you catch signal. If it's stuck on emergency only make sure the slot is turned on under dual sim settings in settings. If it still doesnt work I'd send the thing back :P
4helpful
hello sir,
this emergency calls only is seen only when ur SIM is not activated or ur cell phone dosent catches the signal. Well it shows the signal full but thats the FAKE signal.
If ur SIM is activated try the MOBILE NETWORKS in the SETTINGS option  >  Connectivity
U will search for new networks and u will find ur NETWORK Operator
If ur SIM is invalid u wil continue receving the same message  "emergency calls only"
Top Nokia Cell Phones Experts
Kolbrun...
Marvin
Marvin
matt
matt
