I have a Polaroid i733. My camera works fine with my old 1GB SD card. I bought an 8GB so that I can take video but I keep getting a card error. I lost the manual so I don't know why it won't work. Help!?
The i733 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it won't work. You need to go with SD cards, 2GB and smaller.
If your camera is the type that uses SD cards, then your problem is that the camera was developed in 2004 before SDHC cards were invented. Your camera cannot use them.
At the time your camera was made, 1GB was the max size standard SD card. Then along came 2GB standard SD, but this card also used the same format as previous cards, so yes it also worked in your camera. Now SDHC is a very different format with different file handling (although externally it looks exactly the same). I'm sorry to say, it is very unlikely that SDHC will work with your camera. Here on Fixya you'll see many folks asking why the brand new card they just bought doesn't work with their older camera. 9 time out of 10, this is the reason why.
Hi, I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig. If you want the camera to take a card over 2 gig then you are stuck standard SD cards. The other camera does support the card because it's a higher model.
Had the same problem with our i733 Pink Polaroid. Beeps three times and then shuts off. The reason for this is that the lens is stuck in the partially open position. Because our camera was long past warranty and we bought it for $40 second hand I took the brute force approach. I grabbed hold of the lens and wiggled it from side to side while trying to pull it out (forcefully but being as careful as I could not to damage it) and then there was a small "pop" and the lens came out all the way and the camera was good to go again. Hope this helps.
I wish what I'll be saying will resolve the problem. Unfortunately, your camera can only support up to 1GB of SD card. That's the reason why the 4GB card is not working.
Here's a screenshot of the details regarding your Polaroid camera.
Unfortunately, the A520 does not support SD memory cards with more than 2GB capacity, and doesn't support SDHC at all. (1GB max for MMC cards.) I know memory is much cheaper than when the camera first came out, but in 2005 2GB was about as large as you could get.
