Question about Mitsubishi WD-73736 Television
Picture is dim - Mitsubishi WD-73736 Television
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
Apr 04, 2016 | Samsung UN46EH5300 - 46" LED-backlit LCD...
I have a sony 52 inch wegagate dlp ty that has a dim picture what could be the problem?
If its a Sony and a DLP a lot of times just before the lamp life ends it gives a darker or dim picture---if it gets dim enough set will shut down.
Nov 06, 2012 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 32UDX10S picture is dim with brightness at 100%
The led backlights may be failing or the driver circuit isn't working. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get parts and led testers here.
Feb 12, 2018 | Hitachi 32UDX10S 32" TV
Samung LN-T4061F - Dim Picture
Does it look like a dim black swirling cloud with very faint images?
Mar 24, 2012 | Samsung LN-T4061F 40 in. LCD HDTV
The color is really dim,
i have a wd62528 62" dlp hdtv that shows a picture but very dim. I have tried numerous things including factory reset and checking the lamp. I started to get a new lamp but was told if i have a dim picture getting a new lamp will do nothing. However, Mitsubishi support said that if i have a dim picture but was not continuing to get worse or darker, then they were 100% sure i just needed a new lamp. I'm confused. Will a new lamp solve my problem or no. i would just buy and try but it is very costly. please help
Nov 02, 2010 | Mitsubishi WD-62528 62 in. LCD Television
Replaced wd-62525 lamp, picture dim
Cleaning the mirrors will not increase the brightness much. I would double check the lamp setting in the Menu and also the setting of the picture and brightness settings. Many times these are adjustable independently for different inputs. Besides this, I would look at the Ballast and or the Power Supply to cause the problem. I would recommend a professional to look at it if it is not correctable from the Main Menu of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Picture (video) jumps from bright to dim
I figured it out myself. R243 was intermittently open. Replaced it, and now we can watch the Super Bowl.
Dec 19, 2008 | Toshiba 50H72 50" Rear Projection...
Dim picture
change ur backlight ccfl lamp
Oct 19, 2008 | Audiovox FP1520 15 in. LCD Television
Dim pisture lt2200 projector
If the picture is dim with no distortion then replace the lamp.Usually when the lamp is used for around 2 years it starts to have dim picture before it stops working or breaks inside.
Jul 19, 2008 | NEC Televison & Video
Mitsubishi WD-73736 Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
