Question about Sony Playstation 3 (PS3) Console
No video thru output rca jacks or HDMI from console unit turns on ok
SONY PLAYSTATION3
my console will not give a menu or Video thru the RCA jacks or hdmi from the console ?unit turns on ok
Posted by plasmaman on
  • 7 more comments
  • plasmaman Oct 30, 2007
    tryed resetting console by holding power button until I heard 2 BEEPS AND VIDEO menu came up with vertical pixcel bars all thru the picture, tryed it again and and now I dont get video again?
     did some more checking and  the console seems to be overheating after turn on causing the unit to freeze up the video, the fan is running but in low speed, the powersupply is very hot to the touch what would cause the unit to be running so hot? thanks in advance for help
  • plasmaman Oct 31, 2007
    console is clean inside unit has sound and video for about a minite and freezes up after it heatup
    no sound and vertical video pixcels you can see the menu behind it, when it decides to freeze up it was mfg in Feb. 2007 not to old of a console very clean unit have you had any more consoles with this problem?
  • plasmaman Nov 01, 2007
    were can I get this console serviced
  • plasmaman Nov 05, 2007
    Sony playstation3 heat problem ahfer a miniute of play freezing video and audio
  • plasmaman Nov 09, 2007
    ok thanks for your feed back I will try the web site you have provided
  • mattmro Apr 04, 2008
    The disk drive (not hard drive) failed on my PS3 and then the video went out, is one a symptom of the other I.E. if the disk drive was fixed would the video come on or do you think that the previously mentioned graphics card over heating is the most serious problem, P.S. bought it used so, no warrenty and I am willing to experiment.
    Thanks, matt
Anonymous
Hey guys got my ps3 on ebay prebroken 20gb would run for a minute then freeze.
Here is how i got mine running, replaced thermal, and moved the power supply. The power supply was and is extremly hot. so i relocated it,right now i just raised it up about 2 inches with some posts and a bannana plugs. later i plan on moving the power supply out of the system so i can put the case back on. there is only 2power posts, and one connector with four wires.
Posted on Jun 07, 2008
Greg Stokes
  • 709 Answers
Hi PlasmaMan,
You did the right thing in turning off your PS3 and then holding the power 1/0 button for more than 5 seconds. Since you having true heat problems and your Console is freezing, you have no choice other than to Call SONY at 1-800-345-7669 for support. You may have trouble getting though so email your problem to Sony Support at the following URL http://www.us.playstation.com/corporate/ConsumerServices
I run a Playstation Repair business, and I am unable to get Parts for the PS3. They are very scarce, as Christmas is coming, and my source for parts is getting sucked up at high prices.
Posted on Nov 06, 2007
  • Greg Stokes
    Greg Stokes Nov 10, 2007
    Plasmaman,
    I don't have any good news for you at all. The only thing I can ask of you is to get in touch with Sony Support at www.playstation.com and persue a warranty claim. It sounds like you already opened your unit, but I think that every PS3 console in the world is going to have the same problem. The heat transfer compound that aids the transfer of heat from the Graphics Engine to the cooling system is not holding up to the heat. I have a PS3 console in my Video Game repair shop that suffered the same fate as yours. I cannot get another motherboard. The market is all dried up. Even when I buy a Returned PS3 hoping to get a motherboard, it is also shot. Same fate. Dried up heat transfer compound. Stuff turns to dust and will not help the processor get rid of the heat. The Graphic Engine eventually fails due to scorching heat. This is an obvious Manufacturing defect. Threaten Sony with a lawsuit, and they may pay attention. WWW.playstation.com
  • Greg Stokes
    The phones at Sony Support are too busy to call since all the PS3 systems are dying. Contact them through the webiste.
paul proctor
  • 4,102 Answers
Sounds like it is a problem with the fan it will only freeze when the unit gets hot if it is ok for the first minute then the best thing to do is replace the fan as this should be fast these heat up really quick if you have the problem as soon as you switch on then their is not much you can do but if it ok for first minute or so then replaace the fan this should solve you problem check the fan is easy to turn and not stiff if it is stiff then the fan needs replacing if it is easy to turn then it is probably the unit itself maybe woth replacing the fan before you try anything else
Posted on Oct 31, 2007
Chuck Gluth
    Scholar:
  • 90 Answers
Its the environment a dusty one? Have you blown out the unit to clean it out by chance? How long have you had it?
  • 2 more comments
  • Chuck Gluth
    Chuck Gluth Oct 31, 2007
    Also, when you had no video, were you still getting sound?
  • Chuck Gluth
    Couple more details... how old is your system and what version are you currently running?
  • Chuck Gluth
    One, but the video had failed on it. Needed to be sent back for warranty repair.
  • Chuck Gluth
    what software version is it running? 1.6?
Sony dvp-ns628p, no video output, audio is ok
REVERSE THE RCA CONNECTION FROM AUDIO TO VIDEO, MAY BE THERE'S A PROBLEM WITH YOUR RCA CABLE CHANGE WITH NEW ONE. CHECK THE RCA JACK INSIDE YOUR UNIT FOR LOSS CONNECTIONS
Feb 20, 2012 | Sony Televison & Video
Why will my ps3 not workwhen conected via multi-av cable to the RCA jacks?it does work conected to a hd tv via hdmi
When you use an HDMI cable with your PS3, the system is outputting the signal in a digital format. You need to tell it to switch back to displaying in an analog format to use the RCA jacks, otherwise it won't work. To do this, turn off your PS3. Then, once it's off, press and hold down the power button on the system. After a few seconds, it will beep and reset the output signal back to analog. Just make sure only your RCA cables are plugged in when you do this. Hope this helps!
Aug 26, 2011 | Sony Playstation 3 (PS3) Console
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Oct 07, 2010 | Nintendo Wii Console
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
Ps3 works on hdmi but not on rca jacks ???
Sometimes its a pain to re hook up the cords if you are stuck in HD mode and tryin to go back to Regular or Vise Versa, power off the ps3 press and hold the power button for 3 seconds. that will switch the video card back to default settings.
Oct 17, 2009 | Sony Playstation 3 (PS3) Console
Powers on - no output to TV
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
RCA's work fine but HDMI gives me no picture
Have you already tried:
Connect both sets of cables (HDMI and RCA's)
Go to SETTINGS, VIDEO SETTINGS, VIDEO OUTPUT SETTINGS
Choose HDMI if that' what you want to use.
Just follow the prompts.
If the tv supports hdmi you should have no problems.
Just make sure you use the RCA ports for video since HDMI doesn't include audio, just video.
Let me know if this works.
Mar 03, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
Sony Playstation 3 (PS3) Console Logo
1,219 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
