Xerox Phaser 8400 Laser Printer Logo
A
Anonymous Posted on Mar 13, 2014
Getting error 07.009.42:314 - Xerox Phaser 8400 Laser Printer
Keep getting error
There are a lot of different errors you can get with printers and copiers. to be able to get help, you have to say what the error is? If there was only one error you could get, then that would be a different story.
2helpful
3answers
I m getting problem with IOCTL error with my sandisk 2.0 pendrive..i m unable to format of open..will u plese send me solutions how to get rid of this error...??
I m getting problem with IOCTL error with my sandisk 1gb pendrive..i m unable to format of open..will u plese send me solutions how to get rid of this error...??
23helpful
4answers
Cannot get license, because server returns error code:-47 NComputing Error
Could not create this file.Shall I try again?
Click Start
Click Run
Type CMD and press ENTER.
Enter CD \ and press ENTER.
Enter CD "program files" and press ENTER.
Do you get an error-message?
If not, that's good. If so, what's the error-message?
Enter CD "PrintMaster 2.0 Gold" and press ENTER.
Enter CD "Components" and press ENTER.
Enter CD "Clip Art" and press ENTER.
Enter CD "Travel" and press ENTER.
Enter CD "Europe" and press ENTER.
Enter ECHO Y > "Rusty Fence.jpg" and press ENTER.
7helpful
2answers
HP 3050 Engine Comm error
I have a HP 3050 three in one and I keep getting a engine comm error
1helpful
Im getting an f2 error code in my copy machine sharp 2020
SHARP 2020 F2-31 ID sensor error SHARP 2020 F2-32 ID pattern reading error SHARP 2020 F2-33 Grid voltage error SHARP 2020 F2-35 Grid voltage error
probably need a part
4answers
Windows update error 80240016
Could you download and run the program Dial-a-fix from http://www.softpedia.com/get/System/System-Miscellaneous/Dial-a-fix.shtml
I have tried this with many computers and it worked all the time.
13helpful
2answers
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
