2007 Jeep Wrangler Unlimited Rubicon 2 Doors Logo
A
Anonymous Posted on Mar 13, 2014
Jeep brakes broken - 2007 Jeep Wrangler Unlimited Rubicon 2 Doors
J0sephus
Level 1:
  • Contributor 26 Answers
  • Posted on May 19, 2014
J0sephus
Contributor
Level 1:
Answers
26
Questions
0
Helped
18081
Points
45
Many Wrangler JK's have lift, but few people extend their brake lines. This is particularly important for Rubicon models. The Rubicons are capable of insane wheel travel, by stretching the wheel travel further (lifted?) you could exceed the length of the feeble factory brake lines. Crown manufactures brake line extensions for Wranglers, specifically for lifts.
Back brakes on 2005 jeep liberty locking up
This could be a lot of things. There are springs that hold the parking brake shoes that could be broken, there are springs that hold the regular shoes that could be broken, there are hydraulic pistons that could be over extended, there could be excessive wear on the pads or drums / calipers . You will have to remove the tires too see
Parking brake not working
E-Brake cable is either worn/broken, or could either be E-brake pads are very worn.
2006 jeep commander abs trac.control esp lights are on seems like abs is locking up 0ff and 0n
there is a small switch under brake bedal. when it is broken, you get a warning on your dash light and ABS and related equipment go into safe mode. you need a new one. other reason to this can be a broken sensor on one of brake calipers. those must be checked.
Brake fluid on ground by front passenger tire on 1995 jeep cheerokee laredo.
Hi Debbie, Have the brakes seen to before even moving the vehicle. Could be a broken hose or a leakage from the brake caliper. Whichever the vehicle should not be driven until the problem has been sorted out. Regards John
1helpful
My jeep grand cherokke rear tail lights and 3rd brake light stay on when the jeep is off.
your brake light switch may be stuck and in need of lubrcation, or it may be just broken all together.
look in the back of the brake pedal, your brake pedal will make contact with the switch when you apply the brakes..
try some wd40 on it, before you change it, press it in and out, should be spring loaded
hope this helps..let me know
2answers
1978 IH Scout II park brake won't work. It will not engage in neutral, reverse, or drive. We're able to get it to stay down on the floor, but it's as if no brakes are on at all. (Sorry to put it under a...
so.... either the cable is broken, or the parking brake mechanism is missing, broken, rusted? You should be able to crawl under and watch the cables being pulled as somone works the parking brake lever. If they work ok, then its time to pull the wheels off and ck the brakes.
Brake problems 95 jeep
You may have a broken bolt. Once I saw a broken brake caliper bolt and when the brakes were applied the caliper shifted up and ground into the rim just like your seeing...just take the wheel off and investigate its not that hard.
1helpful
Slamming noise from rear of jeep
Without checking it out it would be hard to pin down, but it pretty much HAS to be one of these things. A broken shock or spring, a broken brake disc or one of the discs in loose in the caliper. If it is a shock making that kind of noise it would likely be visibly broken and show other signs (bouncing, popping).If it were a spring~ sometimes they are just noisy, but they should also make the noise at other times.If you haven't had the noise occur at any other time (rough terrain, tight cornering) it's almost certainly brakes.It's a good idea to replace all four at a time~ in my experience if two are worn, all are worn.
1helpful
2007 jeep compass, 21000 miles, leased vehicle. speedometer and odometer stopped working, auto locks not working, em brake light on, brake is not, abs light on, 4wd light on
leased? take that thing back and dispute that it is not safe to drive. they need to do a complete check up on that vehicle. it could be as little as the the dash malfunctuning, to brake broken and 4wd broken. which idk how that would even be possible. at 21000 miles it may still be under warrenty and there is prob something writen into the lease about problems like this. please go to your dealer
2answers
2005 Jeep Wrangler Emergency Brake Cable seems to be loose when pulled up, but seems to grab & hold when released?
You have to look under the car and see if the cable is broken. If it is'nt then it has to be ajusted.
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
