Skin color is green and seems to be missing other colors
SOURCE: Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
SOURCE: bad color scheme - cannot adjust enough
If you haven't already done so, it may be that all you need to do is adjust the convergence after moving the set. You should find convergence and its adjustments in the setup menu
SOURCE: Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
SOURCE: Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
SOURCE: Skin tones oscillate every 5 seconds, Samsung HL-67A510 67" DLP
Go to this Website and type in your Model number they will List Parts/Prices for your TV, They also have CD Service Manual you can order!
Encompass Parts Distrubtion 1-800-638-3328
When you know Part number you can go to Ebay ,Look under Electronics ,Thats where I find alot of Parts Cheaper then what companys want for them.
You might be Looking at replacing Light Engine or the Dmd Moduel Order the CD it will help you out alot.If one side of screen starts turning Green and wrong flesh tones it is the Light Engine
