Samsung HL-S5086W 50" HDTV Logo
J
Jamie Bush Posted on Mar 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv says check fan 2 - Samsung HL-S5086W 50" HDTV
Jack South
Level 2:
Scholar:
  • Expert 195 Answers
  • Posted on Nov 26, 2014
Jack South
Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
35565
Points
350
A fan has failed--possibly is just dirty. I think there are 3 of them--2 near the lamp and one behind the DMD module. If not--check the fan connectors and make sure they are tight. if all ok--a fan needs replaced.
Samsung tv series sq01 has check fan 2 on screen then will shut off where is fan 2 located and what does this mean
you will need the complete model/serial number for proper part#. To locate which fan is problem try watching to see which one is not coming on at start-up.
#2 fan
you need to replace fan #2 , is located next to the lamp is a big fan compared to the other fan you can buy this fans from any electronics place
This TV is about 16 mpnths old. It has generated a message on the screen. "CHECK FAN NO 2". I can't find any mention in the user manual supplied with the TV
Inside the tv there are 2 fans for cooling the electronics power boards. One of them has failed.
Open the back of the tv , locate and replace it.
4helpful
Check Fan #2 warning came up on the screen
You have 2 fans one fans the Lamp other Fans the DMD module, you may just have a bad Fan! Fans must be running in order for TV to Come on.Yes remove back .
CHECK FAN 2 DISPLAYS ON TV - 2 MINS LATER SWITCHES OFF
Normally we replace the fan because it can't run at the correct speed and the Micro detects that, then sends the error to the screen for you to see.
2helpful
Check fan # 2
Samsung Consumer LCD tv's do not have fans except on the higher end models. The Commercial models do. Yours is a Consumer model. I suspect that you have a DLP tv. In that case replace the Lamp Fan. It is the Larger of the three fans. With the rear cover off, you will see a Blue switch lever on the lower right side of the tv. Hold it in a up position and turn "on" the set with your tv remote. Then look for any fan that is not running. Then order that fan. there is a large fan that cools the Lamp. The other fans are of the same smaller size and one cools the DND chip and the other cools the Ballast.
Fan number 2 in model hls5086w projection tv
the fan may be ok it may be another component thats caused the problem? if you have a meter check the fan you can also get intouch with the manufactuer they will try and help you
50 inch samsung flat screen television
fan # 2 is having problems; maybe missing voltage or broken fan
good luck
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
