Question about Samsung LN32B460 32 in. LCD HDTV
My Samsung LCD (ln32b460dxza) has no picture but power is on
Four-yr-old tv worked great last night but doesn't show any display when I tried to turn it on this morning. The power button on the panel itself blinks off and on when I press it, and it also blinks/responds when I try sending power or menu commands from the remote. There is no display even when I press the menu button on the tv itself, not the source button. I am guessing this is a faulty or failed component of the tv'is hardware...?
Posted by Kasey Kidd on
Tom Chichester
    Top Expert:
  • Samsung Master
  • 55,960 Answers
Failed power supply
Posted on Mar 14, 2014
5 Related Answers
Anonymous
  • 47 Answers
SOURCE: No display
Well I just joined in the world of broken Samsung's. Died Feb. 1st. I had three month additional warranty, but of course it died the day after. Same problem, no video, just audio.
However if you call 1-800-522-7341. This is the number for Executive Customer Relations. They extended my warranty and contacted the repair center for me. Probably won't be fixed by Superbowl Sunday though. I expressed my disbelief that after 15 months a 2400 set can die. I have to call back on Monday for additional help.
Posted on Feb 02, 2008
Anonymous
SOURCE: Samsung LTN1765 has blinking green power indicator, but no picture or sound
Try replacing C51, a 10 microfarad 16v. surface mount electrolytic. It's near IC23 on the upper center of the board.
This part had high ESR on a couple of sets I serviced which
kept the power supply from starting.
Posted on May 10, 2008
Anonymous
SOURCE: No Picture - Samsung LN-S4692D 46in HDTV LCD
I had the same problem and I replaced the t-con board. My t.v. is fixed!!!! I just couldn't see spending another 700.00 dollars for a repair shop to fix it. The t-con board is located at the top of the t.v. once you remove the back cover. Be very careful removing the two plugs at the top of the board which was easy once I figured out how the clips worked. there is a black lever like connection which flips up, then grip with your fingers the tab and slide the tape like wires straight out. The bottom plug is very simple. Also to expose the t-con board you will have to remove a heat shield cover. Once removed there is foil looking tape that needs to be peeled back to expose the board. The board is very sensitive to static electricity so if you have a grounding strap that you can strap to your wrist and ground to the frame while performing your repair. Its best to lay the t.v. face down on the kitchen table with a blanket to protect the screen. Good luck!
Posted on Sep 07, 2008
smbaby
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
Anonymous
  • 6 Answers
SOURCE: Black screen but have audio.
It's a pretty common problem. (If this is a plasma your post says lcd but it came up under plasma.) The no picture but sound problem is usually the y sus board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Posted on Feb 23, 2010
Will not turn on
Probably a spontaneous power supply failure.
Jan 07, 2014 | LG 42" 5400 Series LED HDTV - 42LN5400
No power
replace the power supply board inside tv
Jan 30, 2013 | Emerson Televison & Video
Tv guide doesn't work anymore
I have a Sony model KDL-32BXR6 that the TV Guide first showed no listings this past weekend. Last night when I entered the Guide the screen displaying the Setup/Display Setup Progress came up stating "In Progress". Same thing this morning. Something must have changes with the input signal if this occurred with two different sets.
Dec 04, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
My 55" Dynex lcd TV
take it back.......could be the power supply board....
cheers
Apr 17, 2011 | Dynex Televison & Video
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Tv won't turn on
Although not a great solutin it does allow me to use my fairly new and expensive LCD TV. Heres what I do, UNPLUG THE TV FOR 20 -30 MINUTES, WHEN PLUGGED BACK IN YOU NEED TO VERY QUICKLY PUSH THE POWER BUTTON ON THE TV.
Let e know if this works fo you.
Mar 27, 2009 | Akai LCT3201AD 32 in. LCD Television
Is my brand new TV fried
It may not be fried but it needs to be returned under warranty.
Dec 18, 2007 | Televison & Video
Samsung LN32B460 32 in. LCD HDTV Logo
131 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
