Question about Mitsubishi XD250U-ST DLP Projector
Keystone adjustment not working
When I try to adjust the keystone all i get is a red 'no parking' sign
Posted by Brad Walston on
gmontgome595
    Champion:
  • Mitsubishi Expert
  • 225 Answers
Are you projecting an image at the time? Often times you can not keystone the blue background.
Mitsubishi xd250u DLP projector Disassembly and Lens Cleaning Here is a video of the internal cleaning of this machine.
Posted on Mar 14, 2014
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
How do i fix the keystone
It should be in the installation menu if you can do this by remote or for older tvs it'll be round the back of the tv with some knobs that you can adjust for keystone and other settings
Oct 14, 2014 | Televison & Video
How do I adjust for Keystone on polaview 340 projector?
There is a menu accesible also from the buttons and you can change it there.
Jun 04, 2014 | Polaroid Lamp for POLAVIEW 340 Projector
Keystone not working
Manual: http://www.mitsubishi-presentations.com/wp-content/files_mf/mitsubishi_manual_xd250ust.pdf
Installation>Wall Screen>Keystone
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
My picture is not square how do I fix it
hi dear,
If your picture is irregular shape adjust keystone setting menu ->setting ->keystone
Sep 25, 2012 | Hitachi PJTX100 Multimedia Projector
Whats wrong with my big screen 52 inch
Possible this can be fixed with a professional alignment as the adjustment of the convergence is distorted and so needs a setting.
The Keystone correction and focus must be adjusted.
check this link for tips:
http://htrgroup.com/main.php?section=keystone
Dec 20, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The top of the screen is slanted while the sides of screen and bottom are even, causing the right hand side of screen to appear smaller than the left. Anyway to fix this?
Sounds like a "keystone" problem. Your projector needs to be oriented to the screen in an exact manner. Manufacturers provide "keystone" correct to adjust for mis-alignment. If proper orientation is impossible, use the keystone correction of the unit to adjust your edges.
Aug 14, 2010 | Hitachi Cine Master PJ-TX200 Multimedia...
The whole projection is not square when projected onto the screen. How do we square it up?
if it looks like a trapezoid, you need to keystone it. you can either use the keystone buttons on the top panel or go into the menu under the image adjustments and select the keystone feature.
Jan 13, 2010 | InFocus LP640 Multimedia Projector
The screen is tilted
You can adjust the keystone of the monitor..
this will remove the trapezoidal shape and square up the image to the monitor.
Check on the monitor for the menu controls and you should be able to find the keystone adjustments... allows you to adjust the upper width, lower width, etc...
Nov 27, 2009 | HP Compaq FS 7550 17" CRT Monitor
TILTED IMAGE
reset the settings to factory default.
Jan 26, 2009 | Eiki LC-SM4 Multimedia Projector
Mitsubishi XD250U-ST DLP Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
Jean Sintulaire
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
