Get differebt challange code each time powered on current code is 399 apears to need additional code from gateway rep to be entered to reset
SOURCE: Memory
no it does not support ddr2 ram.
goto this link for mor ingormation.
http://support.gateway.com/s/PC/R/3724/4365sp3.shtml
good luck
SOURCE: When turn on the gateway screen apear, but the
Your power settings may need to be changed, it appears to be going into sleep mode or power saving mode.
If you are using Vista, Click Start> Control Panel > Power Options > "choose when to turn off display" (in the left hand pane) and check that it says at least 10 minutes. Click apply and then ok.
Alternatively, right click on your desktop, select "personalise" and click on screen saver - then select "change power settings" to bring you to the same thing.
If you have xp, right click on your desktop and select "properties" then "screensaver| > "Power" and change it to turn off the monitor after 10 minutes. Click apply then ok.
If your monitor is going to sleep, either press a key or wiggle the mouse to wake it up.
