Televison & Video Logo
r
rajendra Posted on Mar 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to connect headphone avol 32" ALT3280AD? i can use head phone.
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Mar 13, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987023
Points
237762
AVOL 32" TV with surround sound
Check all the interconnections and cables.
Hi plz help me i am using IBM r51 laptop which has all drivers but not able to get sound of it. but when i connect a headphone i can get sound of it. but my laptops speakers r working as i tested mt...
ibm sound card is not faulty, because you are getting sound with your head phone. The head phone jack have two functions 1. to give output to head phone 2. to disconnect internal speakers when you plug in head phone.
The jack for headphone in normal position not give connectivity to internal speakers.
SOLUTION : REPLACE THE HEADPHONE JACK.
I think it will help you.
Where is the plug for headphones?
Thoat model does not have headphone plugin. But if you have a stereo or surround sound receiver with head phone plugin on it, then you can plug your stereo to it via RCA.
4helpful
I want to connect wireless head phones with my Panasonic LCD TV (Model#: TH-L32X9D). There's no additional Headphone slot. So how can I use the wireless headphones. Also is there any way to switch TV...
Most TVs these days do not come with headphone out jacks. If your TV has RCA audio out, you can get a RCA to Headphone jack.
If your TV has no audio outputs at all, you're out of luck.
If your TV is equipped with audio out, there will be an option in the speaker or sound menu of your tv to turn off internal speakers and transmit directly to external speakers. If there is no audio out on your tv, this will not be an option.
Can i hook up a headphone to my emerson flat screen tv
yeah you can, from audio out, you can connect your head phone but after plugin an adopter of audio jacks which convert the audio out jacks to headphone pin.
good luck, feel free for more information
do rate if helped
When i connect headphone in my compaq c700 laptop the sounds came from both the headphone and the inbuilt speaker in a time. please help me.
When you plug your headphones in there is a dis connect the head phone jack should be contacting to break the circuit to the internal speakers. Try a different head phone set. If this doesn't work, the female jack is (in the computer) is probably malfuncitoning. This will require a decent repair man...
My headphones wont work everthing else is fine
Hi There,                The input for the head phone is a 32 ohm input. You need to get the proper 32ohm headphone for it. It seems that you tryed others but there are 16 ohms and 32ohms headphones. But if they do not work then it is your input connection or the device if your headphones work on other devices.You should bring the product back as a faulty device to the store and exchange it with your reciept then.  For the headphone that works on one side it can be the headphone jack that does not fit properly into the hole input (female jack).The one side does not touch or connect for it to work. It happens to cheap headphones and some good ones too. The male jacks on the headphones are slightly off it specification size by a small amount that it is not noticed by the naked eye, so it does not get a good connection.Try another head phone if you haven't tryed that
2helpful
How to connect headphones if the tv doesn't have a headphone jack
Hi!
You can buy a rca to 3.5mm jack adapter from the link---
http://www.amazon.com/gp/offer-listing/B0002KR5Q0/ref=dp_olp_2
And it will help you to use a headphone with your TV.
Thanks
Rylee
Head phones adapter plug
There are three sizes of standard headphone plugs:
TRS audio jack: 1/4"
mini: 3.5mm (~1/8")
submini: 2.5mm (~3/32")
According to specs, your RCA system should accept the 3.5mm jack.
Although the manufacturer can pick any option, most large headphones would have the 1/4" and/or 3.5mm jacks. Small earbuds are more often 2.5mm.
RadioShack, or similar store, would have adapters to convert between these sizes.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
