Question about Acer CRW 4406EU CD-RW Burner
Driversproblem where i can find the driver for my external usb acer cdrom to install on windows wista Business
Posted by gabriel_bars on
Anonymous
  • 34 Answers
Here is the driver
Don't forget to rate... (=
Posted on Jul 05, 2009
Vimal Dhiman
  • 147 Answers
Select hare product and download drivers
http://support.acer-euro.com/drivers/downloads.html
http://support.acer-euro.com/drivers/storage/cr40.html
Posted on Jun 26, 2009
1helpful
2answers
I have a emachine netbook and it say no bootable device
Failed hard drive (assuming one is installed), or could be that it has "lost" the Windows installation.
Possibly a virus, you need to reinstall windows, or hopefully, repair the installation
To do this, as this does not appear to have a DVD rom, you will need the following:
  1. A legit copy of windows (whichever is installed currently)
  2. A spare computer or preferably an external USB DVD Drive (if the latter, skip to the end)
  3. The SATA drivers for this laptop (essential if using windows xp, may not need if vista)
  4. a USB pendrive of at least 4 GB
  5. A USB Floppy drive (possibly)
  6. a copy of win to flash
http://wintoflash.com/home/en/
Uisng the spare computer, extract the contents of the Windows disc to a folder on the spare computers hard drive. Run win to flash and follow the instructions, it will build a boot copy of windows on the pendrive that you specify (it will format the pendrive also).
Copy the sata drivers to the USB floppy drive (you might get away with copying them to the same usb bootable you have just made but I doubt it)
Now, in the bios, set 1st boot to USB drive
Then boot and install, when you reach the F6 prompt, point it to the usb floppy drive and let if find the sata textmode drivers.
Its hould then find your existing windows installation and repair it
IF you ahve a USB DVD / CDROM drive, ignore the above and just install from that, you may need to use a floppy usb to install the sata drivers though
2helpful
I am cannot install OS Xp on laptop blue Il1,because drivers not support
Actually the problem is that the sata raid drivers of the IL1 is not readily available on the windows XP installer package. Another problem is that you cannot use the drivers on the installation because it uses a disk drive for loading and the IL1 have no disk drive or CDROM with it.
The solution is download or get the sata raid driver for the IL1 placed it on a diskette and attached an external CDROM and an external disk drive on your IL1. Open your notebook place the Windows XP CD in the CDROM, place the sata raid driver diskette on the disk drive. Make sure that the booting priority is set to the usb CDROM.
Upon loading of the Windows XP installation, you will notice a message on the status bar below the screen asking you to press F6 if you want to add additional device, press F6 and follow the instruction on adding the sata raid driver. Then your installation will continue till it finishes the Windows XP installation.
There is another way, but a little complicated. It is making a flashdrive installer of Windows XP OS. an integrating the sata raid driver in the flashdrive Windows XP OS installer. there's a guide somewhere in the internet that discuss the process step by step, I just can't remember on what site. I fount it by searching the net, I'm sure you can find it if you have time.
For now that's all I can share. Good luck friend.
D2d recovery miss, in my hd, what I do?
If the computer you are recoverying the Operasting System on does not have an internal optical drive an external USB optical drive will be required to use the Recovery Media.
  1. If applicable, ensure the external USB optical drive is properly connected to the computer and powered on.
  2. Power on the computer.
  3. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  4. Using the keyboard arrow keys, arrow over to Boot.
  5. Refer to on screen instructions to set the first device to CDROM or USB CDROM.
  6. Press the optical drive drive eject button and insert the System CD.
  7. Close the optical drive tray.
  8. Press the F10 key, and then the Enter key to save the changes and restart the computer.
  9. The computer will boot from the Acer Recovery Media, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media they may be purchased at our Acer Recovery Media Order Form.
Drivers for Acer products may be found on the Acer Product Support. Search for the product and download the drivers.
Alternatively, the factory installed drivers and applications can be re-installed by using Acer eRecovery by following these steps:
  1. Click Start, and then All Programs
  2. Click Acer, and then Acer eRecovery Management
  3. You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
  4. In the next window on the left toolbar, select Restore.
  5. Choose Reinstall Drivers or Applications
  6. Choose Contents
  7. Choose the driver or application you wish to install
  8. On the right, click the Install link and follow the prompts.
  9. The computer may restart when installation is complete. If it does not restart, manually shutdown and restart the computer.
Note: For older Acer products, the Acer eRecovery Management program may not be available.
My Notebook acer travelmate 2450 doesn't start correctly. After boot, only appears the following msg "operation system not found". Futhermore, I can't boot linux or windows by CDROM, because when I open...
Check with someone you know to see if they have a USB external CD or DVD drive that you can borrow. Then set it to boot from USB. There is also a possiblity that you have a corrupt CMOS fireware. See if you can download an BIOS firmware update and place it on a external floppy and install. Good Luck
Usb cdrom on the on the optiplex 760 keeps disconnecting. how can i correct this problem? Talleys.
Could be Hardware or Software problem, try below suggestions 1 at a time to pinpoint the problem.
Hardware:
  1. Restart Computer with USB CDRom not attached. Then attach.
  2. Make sure power connector to USB CDRom is firmly connected.
  3. Change to diffent power outlet for power supply of CDRom
  4. If connected to USB Hub, disconnect and connect directly to the computer.
  5. Try a different USB port on the computer
  6. Use a different USB cable (if using an extender, disconnect) Cable should be 6 foot cable or shorter.
  7. Try a different external CDRom drive to verify it is not a problem within that unit.
Software:
  1. Do windows update. Also Choose CUSTOM update (3rd option is drivers). Update all drivers available.
  2. Download most recent drivers from manufacturers website and install.
2answers
I'm thinking of buying an Acer AOA 150-1029 and I'm wondering how I could download the software for my internent card from verizon. I don't have wifi at home and use the internet card(via usb) to access...
you would almost have to buy an external cd or dvd drive that connects to a usb port to install it, or if you have a 2nd pc copy the contents of the cdrom to a usb pen drive and install it that way
1helpful
Acer aspire wlan driver problem
Please visit the below mentioned link to download Windows XP drivers for your laptop:
Acer Aspire 5220 drivers for Windows XP
Thank You
Moden of huawei ETS 2288 WLL
n wista also huawei driver works,,i too tried to install wista drivers for huawei but in vain ..no problem in xp driver itself it will work,,,if it works mail me at [email protected] and don't worry it will work conformly because now im using ny connection in wista using huawei only..
just follow the step to do it:
1)install that driver setup and warning the usb port from modem should be disconnected during this
2)install will finish and wait's for usb port to be connected by displaying port not found,
3)now plug the usb cable and inbuilt windows will appear and say found new hardware and install from the location where you had whether from cd or from hard drive,select appropriate option.4)if it says error during installation ,
4)goto my computer right click and select properties and select device manager in that under other devices categorie you will found your device with question mark,right click that and select update driver and selec from the location where you have that driver back up i.e from cd of location in hard disk..then it will finish installing software and once again it wil ask if automatically it finishes secon time installation no problem or else follow from step 4)
5)now your usb will be identified by your huawei installation process and say port found click next and it will finish setup
6)then once again goto my computer and then right click and than goto properties and device manager and right click on your name at beggining then select scan for hardware changes,,that's all finishes..
7)select connect to from your wista and select new connection and select connect to internet in that dialup ,enter your dial up phone no,username and password..then it will connect....ha ha..
Acer CRW 4406EU CD-RW Burner Logo
Ekse
Steve Sweetleaf
Steve Sweetleaf
