Nokia 5200 Cellular Phone Logo
Question about Nokia 5200 Cellular Phone
Weak singal I have nokia 5200. It always has a signal problem Sometimes it shows no signal and sometimes weak signal....even though I am near to the tower it shows no signal.....I showed it to care center they fixed it and charged me and said it is done. but after 6 months again same problem and the validity has also expired........anybody solving problem here...
Posted by bbh_mbnh on
Anonymous
  • 105 Answers
Plz change your mobile set
Posted on Jun 13, 2009
  • Anonymous Jun 13, 2009
    plz change your mobile set
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
5helpful
Memory showing full and cannot add new configuration settings
Check my blog. I have found and written the real solution for this error. http://inxis.blogspot.com/2009/11/gprs-mms-settings-error-nokia-solved.html
1helpful
Mic problam
Sometimes even a small **** disconnects the mic. It is very delicate. So get it fixed by a qualified service personnel.
6helpful
Internet connection sometimes always failed
your 5200 mobile is come with speed up internet if you have prblms in internet connection speed its problem of sim card company . THANK YOU>
Signal problem
u try to switch off the mob and take the battery and sim.after some time u put all and see it may work. r other wise try the following web sites.......
http://www.simplemobilephones.com/
http://www.wirelessunlocks.co.uk/?gclid=CLGf8v6v7pICFRyrbwodI0l95w
http://www.gsmok.com/index.php?mod=shop&tree=038&gclid=CP-mg5Ww7pICFRspbwodViG_4w
http://www.mobile2mobile.net/unlock/RemoteunlockingMotorola.htm?gclid=CO60i7Kw7pICFQvWbgodCyUK3w
did my solution is helpful for u... yes means post ur ratings to me....
Nokia5200
I am using Nokia 5200 cell phone for the last 6 months.Suddenly voice problem started as it is a flip phone the material base is very soft .If the other party calls me I can not hear the ring tone.when i contacted the service centre they told me that under the Keypads there is a case that holds the cover with 2 small clips ,that is broken which is difficult to find so better apply some adhesive or feviquick , After a month now the problem is of signal.My cell sometimes show no signal or shows only one bar of signal, Temporarily this can be sorted out if I press the phone between the "GO TO" KEY AND THE "GREEN ANSWER KEY" it comes with full signal.then after some times there will be no signal.Can anyone tell what will be the problem ?
Wireless connection in dell laptop
have you installed the driver for the wireless ?
1100 Cellular broken calls lost signal hard to send messages
why don't you change your singal ic of your set. If it problems then go to the nearer reparing shop .And your set will be good.
Apr 20, 2007 • Nokia 1100
Top Nokia Cell Phones Experts
Kolbrun...
Marvin
Marvin
matt
matt
