answer :: 31.4961 in.
But, what you might find more useful is how to quickly convert a measurement using google. Your question, for example, could be answered by going to google.com and entering; convert 800 mm to inches
Also, could be handy to know that 800mm = 80cm or .8m
(cm = centimeters / m = meters). A meter is just a bit more than an imperial yard. Imperial being inches, feet, yards & miles ..the most-commonly used measurements in the United States. Check Wikipedia for more detailed & lesser known measures of imperial measurement. Imperial units Wikipedia
your measurements are in different units, say feet and inches, you can first convert those values to feet, then multiply them together to get the square footage of the area. If you are measuring a square or rectangle area, multiply length times width; Length x Width = Area.
If you measure the height, width and depth you can calculate the volume. You multiple the height by depth by width. Make sure you use the same units for each measurement. For example if you want the volume in cubic feet, make sure all measurements are in feet. If the height is 5 feet 8 inches, you need to convert this to feet, which would be 5.67 feet, likewise for the other two measurements. It wont be exact because there will be bits sticking out but will be near enough. Make sure you also calculate the volume of the door space as that is included in the volume.
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
It means your calculator is currently set to measure angles in degrees.
There are three common units to measure angles. A full circle is 360 degrees, or 400 grads, or two pi radians. The results of the trigonometric functions depend on the current measure, just as you'd get different numbers if you measure a person's height in inches, feet, or meters.
Linear feet are a measure of length (no different from feet); square feet measure area. You cannot simply convert between measures of different kinds of quantities;the connection between them will be specific to a particular problem.A practical example in which this question can arise is in buying countertops for a kitchen. Some materials are sold by the square foot; others (basically those that are extruded, so they come in standard widths) are sold by the linear foot. In order to compare the two, you need to compute the area and wall length for the countertop you want.You can't convert between the two. All you have to do is to make the appropriate measurements so you can calculate the price of each item.The terms used in the lumber industry are a bit confusing.There are two terms that I think you might be mixing up.A LINEAR FOOT is simply the length of a board. If you want to know the area or volume of the board,you need additional information. For instance, 6 linear feet of 1-by-12 has an area of 6 square feet (12 inches = 1 foot, times 6 feet), and it's 1 inch thick, so the volume is 1/2 cubic foot (6 square feet times 1/12 foot). But 6 linear feet of a 1-by-6 board would have half the area and half the volume.A BOARD FOOT is equivalent to one square foot of a 1-inch-thick board. In other words, it is a square-foot-inch (ft^2-in), or 1/12 cubic foot.Linear feet are used for the pricing of a single size such as two-by-fours. Board feet are used for larger lumber that you are more likely to want to compare directly with different size boards .To sum up, neither a linear foot nor a board foot can be converted directly to square feet. A linear foot is a linear (length) measure, and a board foot is a volume measure. You need to know your particular board to do anything more, such as find the area.an example with an" L" shaped countertop will betwo rectangles are 24 by 80 inches and 24 by 36 inches. Thus the area is: 24 * 80 + 24 * 36 = 24 * (80 + 36) = 24 * 116= 2784 sq. in.To get it in square feet, divide by 144: 2784 / 144 = 19.33 sq. ft.The linear measure of this countertop would be 60 + 80 = 140 inches = 140/12 feet = 11.67 feet
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Hold the POWER button down for a few seconds. Thats how you get into the settings. Cycle through options with the measure button. Use the power button to go to the next option (eg, beep on or off). Press and HOLD the power button to exit this mode.
Press and hold the "+ - units" button and hold for over one second. It should then let you select your units of measure. In this case it should be the second selection, which is "0.00 ft". If you lost your owners manual, you can download one at www.engineersupply.com/Manual-and-Help-Docs/Stanley-TLM100-Manuals.pdf. If you find this helpful, please rank the solution.
