Garden Logo
A
Anonymous Posted on Mar 12, 2014
Sprayer is leaking
16 litre sprayer
Aqua system 5 litre repair parts
Sprayer Trigger Handle 4104 Hozelock
Just maybe this link will lead you to the part.
Jun 04, 2014 • Garden
How to use draper 2 litre garden sprayer
Either your not pumping enough or you are not locking the pump down or it has a leak.
Convert ounce into litres
One litre is about 35.20 UK ounces or about 33.81 US ounces.
Garden hand pump sprayer not presssurising
There is probably a leak somewhere in the hosing or gasket. As you try to pump it up, take some soapy water and pour it around sealed areas of the sprayer. Look for bubbles as the sprayer leaks air. Also check the nozzle of the sprayer for a clog. Rinse it thoroughly with hot water until it has cleared any blockage.
1helpful
My 5 litre sprayer was taken from out the front & we found it two streets away with the screw on cap missing; can it be replaced?
If you can come up with a model number I may be able to find your cap. No promises but I will certainly give it my best. I realize this is only a 5 liter sprayer and most likely powered by a hand pump for an air supply. The hardware may or may not have spare parts for your sprayer. However there is a good chance we can locate a cap for you on line.
Kelly
Mar 23, 2011 • Aqua Garden
2helpful
Looking to replace triger (leaks)
NorthStar brand equipment comes from Northern Tool. You can't replace the trigger, but they sell the replacement spray wand here and it's only $11.99. There are other wands, some longer, etc. They are pretty universal -- you just slide them onto the hose and tighten the band clamp. Good luck! If this is helpful, please rate my answer, thanks!
42helpful
2answers
How does one use Rosate 36 weed killer in a 5 litre sprayer? I cannot follow the label as it only applies to fields!!!
The label on the back of the container has 5 pages of information. Pull the right hand side of the label and it opens out. One page of it says 125ml of rosate to 4.88 litres of water for a 5 litre sprayer. I hope this is helpful. J.D
10helpful
Anyone solve the pitchers in puzzle 78
1) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher. (leaves 7 litres in Pitcher 16)
2) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher. (leaves 2 litres in Pitcher 9)
3) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
4) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
5) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 5 litres in Pitcher 16)
6) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 4 litres in Pitcher 9)
7) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
8) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
9) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 3 litres in Pitcher 16)
10) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 6 litres in Pitcher 9)
11) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
12) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
13) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 1 litre in Pitcher 16)
14) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 8 litres in Pitcher 9)
15) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (Pitcher 16 also has 8 litres)
YOU NOW HAVE 8 LITRES IN THE 16 & 9 LITRE PITCHERS.IN 15 MOVES.
Top Stanley Garden Experts
ADMIN Andrew
ADMIN Andrew
goneforever.
Stan Ford
Are you a Stanley Garden Expert? Answer questions, earn points and help others
