Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Kenmore Model 106.56834600 ice maker won't make ice anymore
Kenmore Model 106.56834600 ice maker won't make ice any more. We disconnected the refrigerator to put down tile in the kitchen. It was working great before the move and disconnect. When we reconnected the ice maker, it would not make ice. What should we do to get it to make ice again? We are in FL and need the ice!
Posted by kkharrison47 on
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
Anonymous
SOURCE: kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Posted on Jan 26, 2008
Michael Anderson
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
Posted on Apr 30, 2008
Anonymous
  • 42 Answers
SOURCE: NO WATER IN ICE MAKER
From what you've described, it sounds like you have a defective inlet water-valve.
I would remove your outside rear bottom panel; disconnect the 2 prong wires connected to your ice-maker water valve (blue with black solenoids) and check for continuity using an ohm-meter setting. If defective, replace. Whats' your model #?
Posted on Jan 26, 2009
Anonymous
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
My Kenmore bottom freezer refrigerator model 79570329311 wont make ice
Ice maker has issue.. Is there ice in bottom of ice maker tray? Is it empty? Is the arm in the down position? Is the solenoid working?
Without specifics you get no help.
Jun 25, 2016 | Kenmore Refrigerators
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
My Kenmore S106 626636 Ice Maker is not producding ice.
You probably have the back side of the I/M hitting the fill tube and pushing the white cup at the end of the I/M in some, which would put pressure on the arm and not let the arm fall down free during a cycle.
Sep 05, 2009 | Kenmore Refrigerators
My kenmore, model #56662500, icemaker is not producing ice. I have replaced water filter and shut down both icemake and refrigerator in an attempt to reboot system. I asked for assisitance earlier, but...
Put some water in the ice maker. Wait. If it kicks ice out then change the water valve. if it don't then replace the ice mold thermostat. READ MORE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 20, 2009 | Refrigerators
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
WATER WILL NOT GO INTO ICE MAKER. BUT IT DOES DISPENSE THOUGH THE DOOR
hi. thanks for the question. first is the arm on the ice maker up. or down . should be down.On the back of ice maker, a small tube, that lets water into the ice maker .sometimes it can freeze up .not allowing the water to flow ,in the ice maker .check that. the next check, is the water valve behind the fridge ,at the water source. thanks the appliance doc
Oct 02, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice maker
water valve on back of refrigerator
the water line connects to it
it is leaking a tiny amount of water and it freezes
in the inlet tube to the icemaker.
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore ice maker
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
257 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
