Question about Pride Luxury Line Maxima Scooter - 4 Wheel - Forest Geen
Triton pl3-01 scooter wil not take charge. Reset button on battery is not popped up, when I insert the key, the ''ready'' light flashes then I have nothing.
Posted by bpireland on
Anonymous
I just bought a Triton Products Ltd. electric three wheel scooter that has gone dead.We followed all the manual instructions but the electricity will not go from the battery to the controls Also I can't reach Triton Products Ltd. on any phone numbers they gave us.I'm 77 and need my scooter.
Posted on Oct 13, 2009
  • Leo Koornneef Jun 25, 2012
    I am having the same problem. It appears that one of the power transistors is at fault. I have taken the controller out of the scooter and checked all the parts. The transistor in question is a IRFZ24N which controls the power to the board and the controls. I have ordered a new transistor and hope to install it this weekend when it gets here. I will keep you posted.
  • John Haney
    John Haney Mar 28, 2014
    ny news? I hve PL 3 that quit s well. Plese letme know if you found them. [email protected]
boharm
    New Friend:
Took our scooter apart. circuit board burnt out where do i get replacement part. have a PL3-01 triton scooter.
Posted on May 29, 2011
Anonymous
    New Friend:
Hi, I had the same problem with my moms Triton PL3. I bought it in 2005, she used it once or twice then it just sat for a couple of years. The batteries went dead and I tried to charge it to no avail. My neighbour is great with all things mechanical and advised that the scooter charger may be too weak to bring these batteries back from the dead, so we took the two batteries out of thecase and hooked a car charger up to them - after one day the batteriew were both charged up, now when they run down, the original scooter charger is able to recharge them. Hope this helps.
Posted on May 01, 2010
Anonymous
    New Friend:
I had the same problem, light came on briefly then out. I replaced the batteries ($120 ouch) and still nothing. I took apart the box under the axle and although the circuit board looked good from above, it was all corroded on the bottom side. now I'm tryinig to find a circuit board, but not having any luck.
Posted on Mar 17, 2010
Rick Juliff
What size/watt is the motor in TRITON PL3-01 plus do you still have those control box forsale? email me as soon as you can [email protected]
Posted on Apr 05, 2013
Rob Hill
  • Pride Master
  • 1,414 Answers
What about trying some others batteries ? Just so they can be eliminated, are you sure the chargers ok ?? you be surprised how many I have repaired.
Posted on Jun 13, 2009
Anonymous
  • 39 Answers
If the battery won't hold a charge then it is probably time for a replacement batttery. If you need help finding a replacement check out www.batteryinternational.com . They should be able to help you find the the correct battery for your scooter model.
Posted on Jun 23, 2009
my-mobility
    Problem Solver:
  • 9 Answers
Often a connection problem between the battery and the motor can cause this problem. All seems well but as soon as you require power from the battery, a “bad connection” results in a high resistance and the battery is unable to deliver the required current to the motor. Check that the battery terminals are really tight. Give them a good wiggle. Then check that the cable from the controller box to the motor is secure… don’t swing from it but ensure it is in place. Happy scooting. Regards Chris… [email protected]
Posted on Jun 22, 2009
  • twolsten Feb 17, 2011
    How do I get to the batteries? How do I detach the deck from the chassis to get at the batteries?
Anonymous
Is there a reset button on the triton PL3-01 Scooter
Posted on Apr 27, 2010
Anonymous
MY pl3-01 SCOOTER WAS RAINED ON NOW I HAVE NO POWER INDICATED BUT THE BATTERY TEST OK
Posted on Aug 12, 2009
JOHN HAWKINS
  • 0 Answers
FROM WHAT I UNDERSTAND TRITON IS NO LONGER MAKING SCOOTERS SO YOU WILL HAVE TO WING IT!!! GOOD LUCK
Posted on Sep 16, 2013
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
Why won't it operate?
How many flashes on green light. Count them and you should find in the trouble shooting section of your user manual what the problem is. Most cases you can sort yourself.
Jun 14, 2015 | Pride Celebrity X 3-Wheel Electric Scooter...
Has 2 new batteries, but I am now getting the small green lite flashing constantly. Throttle error? Won't hold a charge either.
Possible controller trip. You may be attempting to install the battery while the key is inserted or the motor controllermay be in overheat protective mode.
Shut down your scooter for a minimum of several minutes to allow the controller to cool. Or, try reinserting the key into the key switch.
download your user manual here and read troubleshootint 9
http://www.pridemobility.com/scooters/maxima.asp#tabs-6
May 31, 2015 | Pride Maxima 4-Wheel 4-Wheel Scooter
My husbands Daytona 4 just started having this charging problem
I'm afraid your batteries have expired. They will show full voltage but the Amps are not being replenished.
Jun 18, 2014 | Drive Medical Health & Beauty
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Nov 04, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Mar 20, 2017 | Cars & Trucks
Rascal turnabout key picture has flashing red light ...scooter wont move
Take a magnet and touch the key symbol on your control.This will unlock it.
Apr 13, 2012 | Amigo Health & Beauty
Have the phoenix s35015 scooter. The battery is charged, put it in the scooter and turn key. All power lights up to the green, lightsheadlight can come on and horn beeps when pushed. The red light does...
make sure you put it in "gear" completely sometime you can get it almost locked but its still in freewheel, flashing light is error code, do a count of blinks and stops, look in the back of book for trouble codes
Oct 01, 2017 | Drive Medical S35015 Phoenixcompact...
My K610i won't turn on. Red light flashes n won't charge.
HI,
That indicates a problem with the battery.Try a reset first.
Connect the phone to the power adapter and then press and hold the power button for more then 1 min.If it still doesn't turn on then remove the battery and sim from the back and then insert the sim back again and hold the power key for more then a min.Make sure you don't insert the battery now.Let me know the result.
Thank you
Aug 02, 2009 | Sony Ericsson K610i Cellular Phone
Pride Luxury Line Maxima Scooter - 4 Wheel - Forest Geen Logo
4,488 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
