Question about Disney 13" TV
Tv parental control on tv
Certain channels get tv protected by TVG or TVPG, other channels come in regardless of rating
Posted by bo56 on
Jude Meredith
  • 417 Answers
yes one other person said she has to put in the password every time she wants to watch that specific channel, maybe try to run it through an old vcr and use that for the tuner? just an idea.
It seems that this model of tv has a querk in its design and has made quite a few people real happy.
JM
Posted on Jul 11, 2008
Tv guide 4 tvg remote
0038,0033,0031. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Mar 03, 2014 | Televison & Video
How to turn off child lock without remote control jvc lt-32sh6
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
OR
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger.
Nov 01, 2012 | Televison & Video
How do I shut off or disable TV Guardian?
Hello
Setting TVGuardian®
Example:
To set "TV Mode Strict", "TVG CC On" and "TVG CC Ch
CC2"
1* Press [SETUP] in the stop mode.
The setup screen appears.
2* Press [ => ] to select "Parental".
3* Press [ENTER].
"Parental" screen appears.
4* Press [Down Arrow button] to select "TVG Mode".
Note:
If the parental lock is set, the highlighted box does not
move. You must enter the password to release the
parental lock first.
5* Press [ENTER].
The submenu ("Off", "Moderate" and "Strict") appears.
6* Press [p] to select TVG mode to OFF at this window, if it is selected strict.
OK.
Jul 13, 2011 | Sanyo DWM395 DVD Player
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
[2]
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
I am locked out of several channels by TVPG blocking control and cannot watch the tv channel I want to watch.
Send me an e-mail how to contact you. I cannot figure out how to sign in access your my profile to cancel your product.
Feb 01, 2010 | Emerson EWF2704 TV
My Vizio turns itself off on a certain channel (ch 17-1 Phila)
I have this same problem with channel 5-1 Los Angeles anyone have any advice?
Aug 29, 2009 | Vizio VW32L 32 in. LCD HDTV
Need instructions to set up remote for GE TV
if its a universal or programmable remote PRESS TV and SET btns in that order ... red light is on steady enter code ( Ge TV code) light goes out Press SET and then use the remote to turn off/on TVG is now undercontrol of the remote.
Please rate our help to keep the service online
Aug 28, 2009 | Universal Remote Control Televison & Video
Need code list for tvguide unvrsal remote
universal remote, rca tv program lennox dvd plaYER 2003
Feb 09, 2009 | Sharp Televison & Video
MANUAL
I need an owner's manual not a service manual. Can anyone help me find an owner's manual?
Jan 11, 2008 | Zenith SY2053S TV
Channels blocked
Hello to all, go to your TV menu and go to V-chip set up, then go thru and see that you don't have any channels blocked. If you do and you are watching a show with that rating, you will receive the "protected program message".
Have a great day!
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Disney 13" TV Logo
55 people viewed this question
Top Disney Televison & Video Experts
Sean Burke
Sean Burke
howard_the_e
Level 1 Expert
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
