I have the first firefly phone from att&t then cincular i am needing to reset password and don't remember the code to do that.
For the Original Firefly Phone:
The default PIN is: 1 2 3 4.
For the glowPhone:
The default Password is: 0 0 0 0
When you first set up your password, you will be able to change from the 0 0 0 0 and enter your own.
If you should happen to forget what password you entered, you can
enter the bypass password: 5 6 7 8 and this will then allow you to go
into Parental Controls and change your password:
- Scroll to and select Permissions
- Scroll to and select Change Password
You will be prompted to enter a new password, then reaffirm it. You
will get a confirmation when the password is successfully changed.
For the flyPhone:
The default password is: 1 2 3 4
When you first set up your password, you will be able to change from the 1 2 3 4 and enter you own.
If you should happen to forget what password you entered, you will need to follow these steps:
- Turn on your flyPhone
- From the Main Firefly Screen, you will need to type in the
following (once you start typing, the screen will change): #20070330#
This will restore your flyPhone back to the default settings, so you can now go back in and reset your password.
or try this:
How can I change my phone's Password/PIN?
- Press and hold the green SEND button until you see ENTER PIN. Press Enter.
- Enter your PIN Number by scrolling though and accepting the four numbers you choose. (The default PIN is 1 2 3 4).
- Scroll to DONE and Press OK.
- If your PIN numbers are accepted, the display will say Change PIN.
- Press OK to let Firefly know that you do want to change that PIN.
When the display panel says SAVED, your new PIN is loaded.
For the glowPhone:
For the flyPhone:
Hope this helped.
Source: http://www.fireflymobile.com/
Jan 05, 2011 |
FireFly Cellular Phone
