If you have a 4ohm sub you can series it with another to make a 2ohm load. this is done by + from amp to + on one sub then take the - of that same sub and run it to the+ of the other sub then you only need to run a wire from - of that sub to the - on the amp. NOTE IF YOUR AMP IS BRIGED THIS IS A 1 OHM LOAD!! IF THE TOO SUBS ARE ON ONE CHANNEL THIS IS A Two OHM LOAD IF YOU ARE RUNNING 8 OHM SUBS THEN YOUR AT 4OHM PER CHANNEL AND 2 OHM BRIGED
That's not correct. That is a "series" connection, but it will double your ohms: so two-4ohm subs will make 8-ohms-and if your amp is bridged; it will make the load 4-ohms. The bridged connection is R on the amp to on the sub, the - on the sub to the L - on the amp. If the sub is 4-ohms and the amp is 4-ohms, the bridged connection makes it 2-ohms. That is why another sub with a "series-bridged" connection puts the load back into the range of most car amps (Be realistic : a lot of amps SAY they can handle 2
