Kenmore 790=46803-991[Frigidare] Lightning burned the terminal block on back. Wires burned off left termnal block post[L1]. I cannot tell if two small black wires should connect to left termanal.? There is a big black and smaller blue wire on left terminal[L1]. Should the two small black ones alo be connected there. Appears one lug had two wires crimped into it. Please send a photo if you have access to a range of this vintage. Thanks a bunch. D
SOURCE: How do I connect the 3 phase / 4pin wires to the back of my defy compact stove?
You got it right,the green wire is ground.it should goto the grounding lug of the unit.
Posted on Dec 08, 2007
SOURCE: Neff Oven
its your NEW oven, id call the manufacture for clarification!!
Posted on Feb 24, 2008
SOURCE: Hotpoint stove timer replacement
what color wires are on the new timer?
Posted on Apr 07, 2008
SOURCE: Where to connect third (yellow) wire to lower heating element
A local appliance repairman solved the problem in ten minutes. Charged me $30.00. The two black wires fasten to one terminal, the yellow wire fastens to the other.
I notice you have billed me for your service. Your ads advice if the problem cannot be solved by your technicians, there is no charge. Please credit my account.
Posted on Nov 18, 2008
SOURCE: Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
Posted on May 24, 2009
