Question about Dell Inspiron 6000 Notebook
Frozen keyboard Dell Inspiron 6000 keys are locked up. The indicator light which looks like a lock w/ the number 9 is lit up? Mouse works fine, but can't type? Tried removing battery and restarted...no help
Posted by jaykat on
David Lagesse
    Novelist:
  • 233 Answers
Solution #1, Go to RUN type in 'msconfig'.
In startup uncheck MotiveSB.
Try to reinstall the keyboard driver. Solution #2
  Sounds like it may also be dirt or some spilled soda.
-- Had the same problem after an OJ spill. --
If you feel comfortable about removing the keyboard, disconnect all the wires and cables, then give the keyboard a thorough washing. Then let it dry overnight.
If that doesn't sound like something you want to attempt, then you will have to take it in to a computer shop.
Posted on Oct 30, 2007
Dell inspiron 1501 laptop keyboard is typing odd numbers and symbols instead of some of the lettters. Examples, the letter "l" comes out "3" . Other letters come out as a back slash, etc. A plug in USB...
Is the Num Lock light lit? This light is the one all the way to the left of several on the computer to the left of the power button (it looks like a padlock with a 9 in the center). The integrated number pad is probably active. Press to toggle this feature off. The Num Lk key is to the right of the various function keys but to the left of the keys labeled Insert and Delete.
I hope this helps.
Oct 16, 2010 | Dell 0Y3740 Keyboard
The lock key is on and that freezes my word document
I have a Dell Inspiron 6000 pv and I am not sure what you mean by the "lock" key. There are 2 lock keys on the computer: Number lock - which doubles as the Scroll lock when combined with the "Fn" key. Either of these can be toggled on or off. To enable or disable, simply press the key. If the lock for Caps or Num is on, the led just left of the power button will be lit.
On the Inspiron 6000, behavior for the NUM lock can be set in the system set-up. I am assuming the issue you are having has to do with how the lock is configured in the setup. Try adjusting the behavior to see if this helps fix your problem.
Apr 02, 2010 | Dell Inspiron 6000 Notebook
Numeric keypad does not respond.
make sure that the num lock is on. There are 5 indicator lights on the left side of the power button, the first indicator on the left is Num Lock, make sure this is lit up.
Mar 30, 2010 | Dell Inspiron 6000 Notebook
My F9 key is locked
Per the Owner's manual, just press the NumLk button once to toggle the number lock off.
" Unexpected charactersDisable the numeric keypad —
Press <Num Lk> to disable the numeric keypad if numbers are displayed instead of letters. Verify that the numbers lock light is not lit."
http://support.dell.com/support/edocs/systems/ins1501/en/om_en/html/trouble.htm#wp1062918
Mar 27, 2010 | Dell Inspiron 1501 Notebook
I have dell inspiron 6000 laptop. The laptop keyboard got locked. I can't use the keyboard and if press any key..it works for the function key. On the laptop, the light with lock symbol (9) is on.
When you turn on the laptop, just before Windows starts to load tap the F8 key a couple of times. If you get a menu, choose Last Known Good.
If that does not do it, and the mouse still works fine, go to Start, Programs, Accessories, System Tools and run System Restore.
Choose a date from before the keyboard problem and let it reboot. Should solve the problem.
Honest1abe
Jan 16, 2009 | Computers & Internet
Number lock won't turn on
When enabled, this allows the user to type numbers by pressing the keys on the number pad, rather than having them act as up, down, left, right, page up, end, and so forth.
in bios is where you can set number lock to enable at start up
so restart and enter set up(bios) and change it to lock numbers at start up
if you need more help just let me know
electech
Oct 23, 2008 | Dell Inspiron 6000 Notebook
Computer Locked?
never heard of lock with number 9 is lit up, could you be more spesific?
Apr 09, 2008 | Dell Inspiron Notebook
Deel laptop inspiron e1505
If you have a spare USB mouse, you might try plugging it in to the laptop. Then go to your control panel. Go to your mouse settings, and be sure that your settings are correct for the touchpad.
Is this a new (to you) computer, or have you had this a while, and then it happened all of a sudden?
When you plug in the USB mouse, it may take a few seconds to recognize the mouse.
Dec 31, 2007 | Dell Latitude CPX Notebook
Dell Inspiron 6000 Notebook Logo
335 people viewed this question
Ekse
Thomas F. Schneider
