SOURCE: Sony KF-WE50
Hello Failrlane.
You have a bad thermal fuse. You must remove the back cover in order to fix this unit. The thermal fuse can be found near the lamp housing. part number for kit: A-1137-954-A
Best regards
Circuitcity
SOURCE: Sony Grand Wega KDF-E55A20 55 in. LCD rear projection HDTV
It is the lamp cover. There is a switch behind it and the post on the cover will slip off the switch. If this switch is not depressed, the tv will go off. No lamp light flashing or anything
SOURCE: changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
SOURCE: Sony grand WEGA 60" with tiny blue dots all over
Sorry but you have a BAD light engine Sony is well know for this part to go bad quick, I think your tv is DLP?
