F03 One or more eyes permanently pressed. Recommend that the glas be cleaned and all objects removed.<br />
Unplug the unit for one minute the plug back in if the error still remains after returning power then you will need to replace the touch control module.<br />
<br />
F12 Electronic board and touch module communication error.Unplug the unit for a couple of minutes.Restore the power if the error return then you will need to replace the board connection cable between the touch control module and electronic control. if the error remains replac ethe electronic control board. If the error comes back again replace the the touch pad.<br />
<br />
F13 Internal CPU checksum error.Recommend you replace the touch control module.<br />
<br />
F22 Key sensitivity problem.Turn power off to unit for a few minutes,if the error returns after power is restored replace the touch control module<br />
<br />
F36 Temperature probe hardware error.Recommend that you replace the touch control module.
Hello not sure volume can be changed but if it can look on the back of the unit or inside the back top plate there will be a tech sheet if it can be done it should be on it
An SE error message on the display of a Samsung ceramic hob means the control panel sensor has been on for too long.
There are a few reasons why the sensor could be saying it's been on for too long:
Touching the key area for more than 10 seconds.
Leaving a wet cloth on the touch key area.
Spilling a liquid on the key area.
By touching 2 or more keys together. All of these can be fixed by turning the hob power off at the wall, then back on again.
Hi, Here below we have aprocedure to try to see if you can save the ERC. F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing. 2. Gain access inside the control panel. 3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC. 4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was. 5. Turn the power back on. 6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound). 7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Couldent find any help, pushed the small switch until display reacted then touched the touch fields one by one in order from top left until the display showed nine. Then beep it all worked again !
Gggenau offered a rep at 400-500 eur for this ! Shame on them !
If the KEY lock is on (key botton flashes when switched on) ... touch AND HOLD the lock symbol for AT LEAST TWO seconds until it beeps, then hold the on/off button for AT LEAST 2 SECS.
If the CHILD lock is on ([L] on all displays when switched on), then:
1)Hold the on switch for TWO secs min (unit swtiches on) ...then
2) touch AND HOLD the + AND - for AT LEAST 2 secs
3) touch the - button once again.
