Question about JBL Boating
Jaguar x-type radio problems
We bought a 2003 Jaguar x-type, the couple we bought it from left the lights on and it completely drained the battery. Since then the radio has not worked or prompted the computer to ask for the security code. When we brought it home yesterday I played around with the radio and got it to work but I am unable to change channels or change the time. The CD player works but you can't shuffle between songs. I tried disconnecting the battery twice with the key turned on to drain all power out. Is there a way to prompt the computer to bring up the code prompt?
Posted by Dan Snyder on
Since I know nothing about the radio on a Jaguar I thought I would not be able to assist on this one. However... I did find a link to the radio.
http://www.the-colliers.net/docs/public/guides%20&%20manuals/Jaguar%20X-Type%202003%20Audio%20System%20Handbook.pdf
Good luck.
Semper Fi,
Z
May 01, 2017 | JBL Boating
Computer will not prompt security code for radio
just call dealership and give last 7 of vin and they will issue the security code for radio
Mar 12, 2014 | 2003 Jaguar X-Type
Buzzing sound from the dash-board, radio will not prompt security code to play.
Replace radio. radio itself is probably shorted out or some of the capacitors have gone bad
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
The engine and battery light keeps coming on
TRY THE ALTERNATOR SWITCH IF NOT THEN COMPLETE
May 13, 2010 | 2003 Jaguar X-Type
Jaguar x-type 2003
remove negative battery wire for 15 min after 15 min then plug wire to battery check lightwill be trun off
Jan 06, 2010 | 2003 Jaguar X-Type
1984 jaguar xj6 left lights on for a couple hours,car won't start but lights and radio come on
you need to make sure you have full battery voltage, turning the engine takes more power than a radio or lights,you can try having someone jump your battery to see if that helps,if it starts give it a good run without alot of lights and stuff on to recharge battery
Dec 09, 2009 | 1984 Jaguar XJ
Engine system fault,park brake fault
4 recalls so far. http://www.motortrend.com/cars/2003/jaguar/s_type/recalls/index.html
unhook the battery for about 15 minutes, that will reset the computer. if you have an anti-theft radio. make sure you know the code first.
Sep 04, 2009 | 2003 Jaguar S-Type
Boating Logo
85 people viewed this question
Top JBL Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a JBL Boating Expert? Answer questions, earn points and help others
