clean the basket-filter-screening of your Singer Juice Giant Model 774:
First, unplug the juicer from the power source and disassemble it.
Remove the pulp container and the juice jug.
Locate the basket-filter-screening and gently twist it counterclockwise to remove it from the juicer.
Rinse the basket-filter-screening under running water to remove any pulp or debris.
Use a soft-bristled brush to scrub away any remaining residue.
Rinse the basket-filter-screening again and dry it with a clean towel.
Reassemble the juicer.
If you need more detailed instructions, you can refer to the manual for your product
You need to use a knife or something to push down the small black release button then it will lift straight off. I got my daughter to push down the button as i lifted.
The white impeller that you attached the basket and blade to is keyed to the motor shaft. There is a small shallow nut that you can remove with a needle nose pliers and pull the impeller off the shaft to see if it's seated properly or damaged. If damaged talk Waring into selling you another at 1 800 492 7464.
The crescent tool has two protruding metal “nubs”. After you open the juicer so you can see the mesh basket that turns around, and a flat grating disc that has two holes that match those nubs. Insert the nubs into the holes and turn counter-clockwise to loosen the disc. (you’ll have to hold the plastic edge of the mesh basket so it doesn’t turn). Once it’s loose, keep turning it until it comes off.You can then remove the disc, the basket and part containing the spout to clean them. Just reverse the process to remount the parts, making sure not to overtighten the disc.
I bought the juicer at a second-hand store in brand new condition however the crescent tool was missing. To remove the flat blade for cleaning, I use a pair of scissors spread far enough to fit the ends in both holes. Hold the basket still while turning the scissors counter-clockwise untill the flat blade detaches. Easy as that! I ordered the tool, but it hasn't arrived yet. Hope this helps!
Generally you will have good luck with this item - however after using
it for a while here is the problem people are stating in other reviews.
You cannot get the basket our for cleaning. Unfortunately there are no
instructions or troubleshooting or anything on the manufacturer's
website for fixing this..
Here's the problem...There are 3 little captured balls on the basket
that engage into holes into the juicer to hold it into place when you
load it. The problem is that over time - the balls get juice in them.
Then you store the thing with the basket locked into the juicer. Then
from sitting in your cupboard - the juice dries and the balls are stuck.
When they get very sticky they do not float in their cavity they are
stuck. Then after you juice the next time - you cannot get basket off.
basket is stuck and you will destroy the juicer if you try to pry it out
with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl
about 3 inches deep with hot water. Then take the juicer with the clear
cover off and flip it upside down and into the hot water. Make sure the
water is covering the entire basket area, but not so deep it goes into
the motor area. I let it soak for about 3 hours, but I don't think you
will need to do it for that long. When I took it out of the water I was
able to pry the basket out with very little force. This is when I
discovered this flawed design with the balls.
Now I rinse the little ball bearings really good after using and dont store it connected. Then before connecting the basket to the juicer rinse the little bearings and push them in to make sure they are freed up before each use.
I used it probably for a year or so about 40 or 50 times without
this issue, but let it sit for about 4 months - which is why I believe
it caused these balls with juice in them to get so frozen I couldn't
remove it.
Good luck. It worked for me.. this should work for you!
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
