Pantech Ease P2020 AT&T Logo
Question about Pantech Ease P2020 AT&T
Changing language back to English on Pantech Ease phone
How do I change language on AT&T pantech ease phone.
Posted by John Pallaria on
Notre Monde, India
    Scholar:
  • 55 Answers
Follow these steps carefully
1) Open menu
2) Navigate to Settings (the one with gear icon)
3) Navigate to Phone (the one with phone icon, fourth one)
4) Navigate to Language (first one)
5) Navigate to Screen Text (first one)
6) Select the first option.
Hope, you will solve the case.
Posted on Mar 14, 2014
3 Related Answers
Anonymous
  • 2047 Answers
SOURCE: how do I change the
Changing mobile phone housing are usually quite straight forward. First take off the back of the phone where the battery goes in next try to determine if the back casing of the phone is screwed to the front. If yes locate the screws and take them out to allow for ease of removal of both the front and the back. Although often times the casing is usually still held in place by clipings which are in built with the casing.
Also you must know that the screws which are used for mobile phones are mostly different from the conventional star of flat screw drivers. So incase your screw driver does not open it do not force it as the screw combination might be different.
Hope this solution has been helpful?
Posted on Mar 23, 2011
Anonymous
  • 19 Answers
SOURCE: i need a manual for pantech ease cell phone My
You can download a complete manual for free at pantechusa.com/support/ease
You can also find a free online interactive guide that walks you through all the menus and feature of the Pantech Ease P2020. It is at this address: pantechusa.com/demos/ease/demo/
To go from "Advanced" to "Easy" mode press "Menu" press the end key once and that will take you to the front screen with the wallpaper picture, the time and date display and at the bottom you will see: (from left to right) "Dial", "Contacts", "Inbox" and "Menu". Press the "Menu" icon and this will take you to the first Menu screen. Next you need to quickly swipe your finger across the screen from left to right. This should take you to the last menu screen which should have in icon labeled "Settings" with a picture icon of a couple of gears. Press your finger on that icon picture and you should find yourself at the "settings" screen. The top selection on that screen should be "Phone Mode". Go ahead and press your finger on that selection. Now you should be at the "Phone Mode" screen at it is here that you can choose between "Easy" and "Advanced Mode". After pressing your finger on "Easy Mode" be sure and press "Save at the very bottom of that same screen. This will immediately activate the "Easy" mode.
If you ever need to go back to "Advanced" mode you will find it to be much easier. From the front screen press "Menu", then press "Settings" at the bottom of the next screen. Now press "Phone Mode" at the bottom of the next screen. Finally press "Advanced" on the "Phone Mode" screen and then press"Save at the bottom of that same screen. The will immediately activate the "Advanced" Mode.
I hope this solution is helpful for you.
Posted on Jul 07, 2012
Anonymous
  • 4 Answers
SOURCE: how to unlock the back of pantech ease P2020
Did you mean the battery cover? If so put thumb on arrow and push down to bottom of phone it should slid down and open.
Posted on Nov 30, 2012
2answers
How do i unlock pantech c300?
If your phone purchased in USA on or after 26 January 2013, please contact your network/service provider and get their permission to unlock your phone with a help of third party online unlocking service provider.Using network unlock code is the best way to unlock your Cingular locked Pantech C300 mobile phone.If you need an unlock code visit Classicunlocking.com Here you can unlock your mobile phone within a day.
How to unlock the back of pantech ease P2020
3helpful
How can I remove battery cover on pantech ease
The back cover on the Pantech Ease is difficult but not impossible to remove. This is what works for me: First turn the phone off (for 2 reasons). Most importantly the phone should be off before you remove or replace the battery, memory card or sim card. The other reason if because it is almost impossible to remove back cover without accidentally pressing any buttons and/or the touch screen (I accidentally called someone once). Next remember The Trick is All Thumbs. On my Pantech Ease it is almost impossible to open the back cover without using Both Thumbs Pressing Down while simultaneously using Both Thumbs to Slide the cover off. It also seems to work better if you hold the phone sideways so when you are pressing and sliding the cover if sliding off to one side or the other. The bright side of having a cover like this is that the cover does not easily pop off when you don't want it like other phones I have owned in the past. Hope this solution is helpful.
2answers
A friend gave me a pantech c530 it needs to be unlock any help?
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
The phone is locked
Pantech Ease and PANTECH P2020 Is different Phones.They not same Phones,So you need to Unlock it means You can get the Code from here
Onlinegsmunlock and Unlock Your Pantech P2020 and Ease.
3helpful
I dropped my pantech ease and the screen shattered but the phone still works. Is there anyway to replace the glass?
Hi kellyward309,
You can buy a replacement front housing (including the glass) on eBay.
Type in "pantech ease housing" in eBay, currently there is a USA seller with Pantech Ease front cover for about USD$20.00.
Mar 14, 2011 • Cell Phones
4answers
Unlock pantech c3 rogers
can you help me unlock my pantech c3 cell phone. I dont have the master code.Pls. Thank you
Top Pantech Cell Phones Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
