Toshiba Satellite A105-S4004 Notebook Logo
Question about Toshiba Satellite A105-S4004 Notebook
Driver for apple video camera
Need a driver for this device
Posted by Dale Willard on
2answers
Connecting to ipad
No direct connection possible right now. Perhaps in the future?
To get your video on the iPad you could use a memory card reader, or a wifi memory card. But both are not capable to stream video streams life.
Perhaps Apple, can be moved to bring a connection tool, for video, but there is noting right now.
tip
Ipod touch / or other ipod shows up as camera
I just fixed this problem in a live chat few days ago.
You need to open device manager.
right click my computer, select manage, on the left side find device manager.
Find the ipod from the list, click on "update driver", don't look online,
Then select install from list.
then
You should find 2 or more drivers in this part, select the ipod USB driver name may be different, just don't select the still camera that it is now using.
if it still installs the still camera driver for it
open up search
type in usbaapl
note where that driver is stored.
for example at c:\program files\apple\itunes\ (I just made that up its probably in another folder that's why we are Searching for it with the search tool)
Then go to device manager select the ipod, update driver, manually(as above), have disk - go to the address where the usbaapl is stored and click ok. it should find the driver, continue, it should install the driver, and you are done.
Thanks,
Ekse
on Jul 10, 2008 • Apple iPod touch
Camera not recognized by computer
Most likely the drivers are corrupt for the camera on your computer. I don't use Apple products so I can't help there.
Did you check the camera settings? Most have a option to allow or set up connection to computer which may have been inadvertently disabled.
If this is not the case. Open your control panel on the Dell and select "Hardware and Sound" then "Devices and Printers." If you see the camera there, select options (right click) and update drivers.
If it is not listed, go back to "Devices and Printers" and select "Device Manager". From the window that comes up, see if there are any highlighted with problem. If there are, then select that category and update drivers from there.
Also you can go to Canon for the software related to your camera. It may very well be a glitch in the camera software itself rather than a computer problem since you are unable to see it on three different systems.
Hope this helps. I know first hand howe issues of this sort are frustrating.
Vivotek PZ6114 software apple
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
3answers
My ipod touch only showed up as a camera ive tried everything to fix it ive even tried to go in to manage my computer selected my ipod (listed as camera) and went to update driver but when i went throught...
Apple media products such as the iPod Touch require the use of iTunes for managing media. Unfortunately, you cannot plug the iPod into the computer and simply copy media to or from it. You will have to install iTunes and import your media, then sync the iPod.
You can download iTunes here.
Once you have installed iTunes, open the program and connect your iPod. You will see it listed in the left pane. You will find support for iTunes and iPod on Apple's website. They have some very well-written support articles and videos that explain most of what you need to know to get started.
Hi i have windows 7 and i found this to be a common problem. my iphone and itouch do not show up in itunes. and wen i furst plug my iphone in it shows up as a camera in devices. please help me get my...
hi , it sounds as if your apple services driver is not starting.
  1. Connect the device to the computer.
  2. Quit iTunes if it opens.
  3. Click the Start menu, right-click on Computer, and choose Properties.
  4. In the upper-left corner, click Device Manager. The Device Manager window should open.
  5. Click the plus (+) icon (or disclosure triangle for Windows 7) next to "Universal Serial Bus controllers" to expand this selection.
  6. Locate
    the Apple Mobile Device USB Driver in this list. In some cases, you may
    not see this, but will find "Unknown" in its name. In other cases,
    Apple Mobile Device may be located in a different section of the Device
    Manager, such as Other Devices.
then all you do is click to restart driver
good luck
nick
2helpful
2answers
My webcam isn't working on Skype during video calls
To set up your webcam, please follow these steps:
Download and install the most recent drivers for your video device. If your video camera does not have drivers for Mac OS X, please use the drivers.
Select your video device in Skype under Skype Preferences- Video. This step is not required if you have an Apple iSight.
Make sure the option Enable Skype video is ticked. You can also set video privacy settings to desired options in the same window.
The minimum system requirements for Skype 2.0 for Mac are a Mac OS X v10.3.9 Panther or newer, G4 800 MHz and above, any G5 or Intel processor, 512MB RAM, 40 MB free disk space on your hard drive and a microphone.
Suggested webcams include Apple iSight, Philips SPC900NC, or Logitech QuickCam Pro 4000.
Video and call quality may vary greatly in environments with conditions below these recommendations. Please be sure, that your webcam is connected and not in use with another program.
If you experience any issues with your webcam, please contact the manufacturer directly.
Please let me know if you have any further questions or concerns.
Thanks.
8helpful
5answers
I want to download transcend mtv converter software to store vedios in ma ipod. i hav t.sonic 850 8gb ipod
Jus t try to use Leawo MKV Converter!
http://www.leawo.com/mkv-converter/
Leawo MKV Converter lets you make the most of MKV videos by converting MKV video to any popular formats, for example, MKV to AVI, MKV to MP4, MKV to DVD, etc. With this powerful MKV video converter, you can handle any MKV videos with different resolutions, e.g. 720p and 1080p, and convert them to be playback-ready on iPod, iPod Touch 4, iPhone, iPhone 4, PSP, Apple TV, Apple TV 2, Windows Mobile, Android Mobile, Zune and more media devices.
2helpful
3answers
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Top Toshiba Computers & Internet Experts
David Shaub
Steve Sweetleaf
Steve Sweetleaf
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
