Question about HP PSC 1610v All-in-One Printer
Black Line in scans
I have had my 1610 for close to a couple years had been great, but lately I have had a black line running through the middle of my scans. I have tried reseting to factory defaults and unplugging it too.
Anyone have any solutions to my problem?
Posted by sandiego55 on
Eric Engel
    Scholar:
    New Friend:
  • 122 Answers
You'll have to take it apart and get at the scanning unit (the little light that moves back and forth.  They don't make a manual for that (that I can find) so it'll be a bear to figure out.
But once you get it apart, clean the scanner (lights) and any mirrors you can find.  Then clean the glass.  And look at where the scanner rests when you're not using the copier.  On the underside of the glass, just above this point, you'll see a white strip.  Make sure it's clean.
Oh...this is assuming that it only happens with copies and not with computer prints.
Posted on Oct 30, 2007
I have a big black line down the middle of my scans
If dirt sticks to the scan module, it will be scanned continuously and appear as a line in the output. Clean the glass with Isopropyl Alcohol. Dont use any other solvent.
S. Mohan, India
Mar 12, 2013 | Canon DR-5010C Scanner
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Psc 1610 all in one scans with black lines down the middle
Open flat bed, remove scan camera, clean internal reflector glasses with ear buds to clean dust on it, as well as clean flat bed glass with galss cleaner both sides fix it back, check copy & scan...
Feb 01, 2012 | HP PSC 1610 All-In-One InkJet Printer
LARGE HORIZONTAL BLACK LINE- PSC 1610 PRINTER COPIES
NO, I DID NOT GET IT FIXED. YOU TOLD ME TO SCAN SOMETHING TO THE PC, WHICH I DID. SENT PAGE TO MICROSOFT WORD AND THE BLACK LINE WAS STILL THERE. I BELIEVE MY SOLUTION IS TO JUNK THIS THING AND BUY ANOTHER.
Jan 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Charlie
Mar 31, 2009 | Televison & Video
Black line down the middle of my copies
It sounds like you have a dead spot in your imager.
Feb 20, 2009 | Dell All-in-One 968+ Wireless Network Card...
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Feb 04, 2009 | iLO V27DMBX Television
Black line down middle of scan
Well I hate to give out bad news but if that line is in the exact same location on every scan it means that the element (the scanning light) has failed. Sorry that I could not earn a FixYa for you. If you need to replace the scanner I have had excellent luck with Epson scanners. Here is a link to a few on Amazon.com for refrence.
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps
&field-keywords=epson+scanner&x=0&y=0
Just copy the link and paste it into your web browser. there are also some very good all in one options. I have had this one for a year and it works well:
http://www.amazon.com/C7280-Photosmart-All-Printer-CC567A
/dp/B000UY6M2G/ref=pd_bbs_sr_4?ie=UTF8&s=office-products
&qid=1210270089&sr=8-4
Hope that was at least helpful.
Take Care,
-WN
May 08, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
HP PSC 1610v All-in-One Printer Logo
70 people viewed this question
Ekse
efs_perpends
efs_perpends
