Question about Acu-Rite Acurite Wireless Indooroutdoor Thermometer 00606
I have Weather Center 00436 and the outside temp is stuck at -40. I have changed batteries in both display and sensor. is there a reset button"
Posted by Bridgette Tucker on
  • Bridgette Tucker
    Bridgette Tucker Mar 15, 2014
    My weather station is stuck at -40, even with no batteries in the sensor unit. Everything else is working fine. I even have the sensor unit in my house.
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
Acurite weather forcaster not showing outside temp
Here's the manual for the AcuRite Weather Forecaster. If it's not showing the outside temperature, make sure the A-B-C switch is set to match the display unit. Not doing so might be the reason it's not synchronizing and displaying the outdoor temperature. https://www.acurite.com/media/manuals/75077-75107-instructions.pdf
Apr 10, 2016 | Measuring Tools & Sensors
Outdoor temperature reading shows -40 with wind chill -62. Outdoor temp is in fact +45.
We would recommend a hard reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac, and then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall battery into the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected]
Mar 17, 2015 | Chaney Measuring Tools & Sensors
How do I reset the time on my smartgear weather station
I have two of these and they lose the signal occasionally. Per the manual: Make sure all batteries are good and then press the TX button on the remote sensor for 3 seconds so it sends a wireless signal to the weather station. It should beep. Then on the weather station hold the CH button for 5 seconds to make it search for the transmitter until the outside temp appears. Just removing batteries and reinstalling them in various orders doesn't work. You must re-establish the wireless connection between the outdoor sensor and weather station.
Mar 08, 2015 | Measuring Tools & Sensors
How do I program Taylor in/out thermometer-clock and get outside temp to register? How do I program the clock?
Hit reset next to batteries to have it sync with outside temp sensor. Push mode button to scroll thru date, time. Use up and down button on back to adjust numbers.
Mar 03, 2015 | Taylor Measuring Tools & Sensors
I have inherited a IT-915 MHz wireless temp. station--the batteries in outside sensor were taken out but still in box-can i put them back in at this time to reset the sensor and how to set them ?
You shoud use new batteries because you dont know how old the ones that are present are. You should also use lithium battteries in the weather station sensors because they last longer and have better low temp response. The batteries should have marks on them that correspond with the marks inside the sensors.
Feb 23, 2013 | Weather Channel It 915 Mhz Solar Powered...
How do get the outside temp to work.
Bring the outdoor sensor inside. Take batteries out of both the sensor and the main unit. Wait 10 minutes. Put batteries in remote sensor. Then put batteries in main unit. Don't touch any of the buttons for 10 minutes or until the outdoor temperature is displayed. If still not displayed after 10 minutes then try again.
Dec 26, 2010 | La Crosse Technology Wireless Thermometer...
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
Outside temp stuck on -40
when its at -40 usually its because the ambient temp sensor is not sending the proper signal to the controller.. it may just be disconnected.. the sensor it behind the grille.. it has a 2 wire connector to it ... itf its connected it may havea broken wire from body damage in an accident... its rare that the sensor fails..
Jan 30, 2009 | 2001 Chrysler Town & Country
Rf tech 433 mhz
I had the same problem and finally found my manual. Here's what to do, everyone!
1. Take back panel off the sending unit, where the three batteries are, by unscrewing the 4 phillips head screws (assuming you, like I, had put the screws back in after installing new batteries). You will see a little gray button in a hole above where the batteries are; the little button is one you can push down with the same phillips screwdriver you took the 4 screws out with - don't do this yet.
2. Now, hold down the "channel" button on front of receiver panel for 2 sec, until the dash in the "ch" box and the place where the temp is supposed to be starts blinking.
3. Now, while these indicia are blinking on the panel, push the little gray button down and hold it for 2 seconds. This causes the transmitter to "register" with the receiver. You should now see a 1 in the "ch" box and get a temp reading.
4. Put screws back on, put receiver where you want it, proceed with rest of your life.
Feb 21, 2008 | Computers & Internet
Acu-Rite Acurite Wireless Indooroutdoor Thermometer 00606 Logo
755 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
David Gust
ray gallant
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
