Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
No water from bottom of the door to water dispencer
Posted by Robert Rutherford on
mdaeng
    Problem Solver:
  • 18 Answers
Pipe will be creased try it with the door open and see if you get water through then if not then it will be badly creased blocked goodluck
Posted on May 30, 2014
Ge will not dispence water or ice and the light on control panel blinking green cannot change from ice to water.
at the bottom of the door is a grill remove and check the wireing plug for corrosion if it has a lot of green around it you will have to hard wire it wire for wire has bad connection .
The cold water dispencer freezes in my amana bottom freezer refrigerator
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
ZANUSSI 695 Integrated Dishwasher
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Water won,t dispence from the freezer door. the water pumps to the bottom of freezer door,but don,t come out of the nozzel.
Water line in door is frozen. Set frzr warmer and leave door open an hour or so so it thaws out.
1helpful
Water dispencer not working
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
2answers
Refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
2helpful
Dripping water dispencer
Dripping problem is from 2 sources.  Faulty water valve or faulty water connector behind refrigerator.  If the dripping is constant and doesn't seem to end, then it's a faulty water valve.  If the dripping stops after awhile, then the water connector is allowing air into the water line causing the dripping.  Have that connection checked to make sure that it's securely in place.
7helpful
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
Top Hotpoint Refrigerators Experts
Dan Webster
Dan Webster
jdthefixer
Michael Thomas
Michael Thomas
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
