Question about Sony IT M804 Corded Phone
Program / Record Greeting message
Have had this phone IT M804 for 2 plus year but can't find the box or manual..I need to change my recorded greeting message but can't remember how to do it.  Pls. e-mail me at [email protected]
Posted by Ellsworth on
  • Anonymous Mar 14, 2014
    HOW TO CHANGE GREETING ON PHONE
Anonymous
    Novelist:
    Scholar:
  • 125 Answers
Try this website at fixya.com There is an 804 manual there. Hope this helps.
Posted on Jul 25, 2008
How to change my recorded greeting on kx-tg6431
You can change your answering system message by pressing Menu (with the phone in standby). Then use the up/down arrows to select Answering Device and press Select. Navigate to Greeting Message and press Select again. Then navigate to Record Greeting. Use the up/down arrows to select Yes. Wait for the beep and speak your greeting. Then press Stop when your message is done; the system will stop recording after two minutes. Press Off to exit the menu system. Your greeting will be played if the Answering system is on and the greeting message time is not set to "Greeting Only". You can also access the Record Greeting sub-menu by pressing the following keys Menu # 3 0 2 .
See page 32 of the manual for more on recording a greeting. The manual is available from Panasonic here: https://panasonic.encompass.com/shop/model_research_docs/?file=/MSC/om/KXTG6431T.pdf . You can also see more about the phone's menu on pages 20-23.
I hope this helps.
Apr 12, 2017 | Panasonic KX-TG6431
How do I record the Main Message people hear when they call my company?
Note: Voicemail may ask for mailbox and password. Please consult your owner's manual for the credentials.
To change Main Greeting messages, here are the following steps:
-Go into the Supervisor Options
- To Access Supervisor Options:
- From main menu, press 6 for Supervisor Menu
-Press 2 for Routing Box Administration
-Enter Box Number that you are changing / recording
(Main Day Greeting is box 800, Main Night greeting is box 801)
-It will repeat the number you entered and prompt you to press 1 if its correct
-Press 3 to Modify
-Press 1 for Greetings
-Press 2 to Record Greeting
-Press 1 to replay current greeting or Press 2 to record greeting
-Press * (star) for current greeting
-Record greeting.
Jul 17, 2014 | Comdial Dx-80 7260-00 Digital Executive...
Voicemail change message
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
Nov 21, 2013 | Nortel T7316E 2-Line Corded Phone
We have a business panasonic xdp system and are unable to change the greeting message. How do we access this initial contact message. We are able to change individual mail boxes on the system.
Assuming you dial 165 to get to the voice mail system (a TVS type box) you press #6 * 998. You better know the password if it asks and you need to know where the greeting was recorded. It sits either in a Custom Service box (1-100) or a Company Greeting (1-32).
I'd be hoping that someone left a TVS Installation and Programming manual with cheat notes lying around. If not, there's a way into the TVS via a terminal program and the DB-9 serial connector on the box. That will let you read the database.
Your Panasonic installer/dealer might have the passwords and setup in their records.
Carl
Jun 28, 2011 | Panasonic KX T7220 Corded Phone
How do I change the message... we set it a few years ago...can't find book
Oops, I posted the info for this on the VTech problem below sorry.
To change the message, first make sure your phone has the correct date, time, year, am or pm, etc.
Now, to Record Greeting - if you don't record your own greeting, a pre-recorded greeting message is used.
So, try this:
1. (Menu) press
2 (Go to Answering Device" with up/down arrow, press OK
3 (Go to "Record Greeting" with up/down arrow, press OK
4 After the handset beeps, speak clearly about 20 cm (8 inches) away from the
microphone.
5 To stop recording, press (OK)
6 (OFF)
Hope this helps.
Mar 30, 2011 | AT&T DECT 6.0 Cordless Phone System with...
HI! How do I change the message on my phone?
You can record your own greeting message (max 2 mins & 30 secs). If you don't record a greeting mesage, a pre-recorded greeting message is used & asks the caller to leave a message. (Make sure your phone has the correct date, time, year, etc.)
To record a message:
1. Menu (OK) the "Answering Device" (OK), the "Record Greeting" (OK)
2. Then after the handset beeps, speak clearly about 20 cm (8 in) away from the mike.
3. To stop recording, press (OK)
4. (Off)
Mar 30, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
How to record greeting message
Page 21 of the manual: http://service.us.panasonic.com/OPERMANPDF/KXTG5100M.PDF
1 Press and hold [GREETING] until
“Record greeting after the beep” is
heard.
2 After the long beep, talk clearly,
the MIC (microphone).
• The elapsed recording time is
displayed.
• If you record for over 2 minutes, the
unit will stop recording.
3 When finished, press
[GREETING] or [STOP].
• The unit will play back the recorded
greeting.
• To change the greeting, start again
from step 1.
Aug 26, 2008 | Panasonic KX-TG5100 Cordless Phone
How do I change the voice mail recorded message? How do I get a manual for this existing system?
IF you know the password for the mailbox then log into the voicemail by dialing the Stratagy access code, after Stratagy answers dial * , then your user ID mailbox number plus #, then your security code plus #. The User Main Menu plays, press 2 to change your greeting, the Select Greeting Menu plays, press the greeting number, the Record Menu plays, press 2 to record your greeting, Record greeting, as soon as you finish press #, the Record Greeting Menu plays, press 1 to review or 2 to re-record. Press 9 to save and return to the Select Greeting Menu and 9 again to return to the User Main Menu, hang up at this point.
Jun 08, 2008 | Toshiba DKT-2010 Corded Phone
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
10. Press the ChOOSE softkey
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Sony IT M804 Corded Phone Logo
105 people viewed this question
Top Sony Lands Phones Experts
Al Ursich
Level 1 Expert
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
