Question about Hitachi 61UWX10B 61" Rear Projection Television
Color convergence problem
My Hitachi 61UWX10BA Rear Projection TV is acting up. All 3 colors are mis aligned on the left & right. Middle section seems to be fine. The unit has Magic Focus button but did not do anything to correct the problem.
Is this problem can be adjusted somehow or need to replace the convergence board?
If I replace them, could you tell me where to buy and the correct part number for the model? Also, do I need to replace anything else?
Thank you fro your reply in advance.
J.P
Posted by oldnuke on
  • 6 more comments
  • bevinssign Dec 04, 2007
    Same problem, after blowing circuit breaker, tv now has color separations in arches that the magic focus won't fix. Need advice on how to bring the three pictures back to one. Thanks
  • kb5bet Dec 22, 2007
    Did convergence. Have arcing at top and bottom that I can't fix. Have replaced everything suggested in previous answers. Can't get to website listed in problem solution...I get an error that website is not found.
  • Anonymous Dec 30, 2007
    I was going to replace the stk chips and the resistor from position rk50 on the covergence board because it is open but the color bands are burned so that I can't tell what the value of the resistor was & I have'nt been able to locate a schematic for it
  • reyc May 05, 2008
    Have a problem with color convergence. Tried auto focus button several times but did not fix the problem. Thanks for your help.
  • Anonymous May 16, 2008
    Letters and numbers appear as red and blue ghost images. Most of the screen is blurry due to this.
  • buddy000000 Jun 14, 2008
    My Hitachi 61UWX10B after a series of power outages I noticed the image are out of focus. Tried Magic focus button from SetUP menu and also the Magic focus button. During Magic focus funtion the green color dsplay of the word 'magic focus nd small bars are distorted and shows horizontal lines. This is only true on the green color during the 'magic focus ' process..
    Will this be the same resistor being broken as already reported in the solution response?
  • LB1and2 Jun 28, 2008
    Same problem as everyone else. All three colors are misaligned, leaving a 3-D imagine on the screen. With no fix when using the magic focus. How do I go about getting the correct information to make the repairs needed?
  • hitachi123 Jul 31, 2008
    my Hitachi 61UWX10B has convergence problem with error code 3 i tried the manual way but it did not work, is there a service manual i can get to replace the board or the chips on the board.
    any advice would be helpfull.
Anonymous
My blue gun was out of alignment. I was receiving an error code 4 during magic tune. I ordered the service manual from manualscenter.com. The service adjustment/ trouble shooting guide section is awesome. The problem ended up being a bad resistor (RK54). Mr. "Guest", RK 50 is a 1.5 Ohm 1W resistor. I wouldn't attempt this repair unless you can read schematics and are familiar with high voltage components. A HV capacitor is right next to the convergence board. Good luck.
Posted on Jan 03, 2008
  • Anonymous Jan 03, 2008
    Sorry. RK50 is a 2.2 Ohm resistor. RK54 is a 1.5 Ohm.
Lashawn Robinson
    Genius:
  • 1,153 Answers
Www.ptscorps.com
Posted on Nov 26, 2007
How do i fix a color alignment problem?
Tries push the button said FLASH FOCUS or manual + - convergence alignment adjustment?Yes,n o,used?The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv have a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too on the convergence board,must replaced these parts to fix it.To solved tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 27, 2011 | Hitachi 46F500 46" Rear Projection...
Periodic color scrambling - out of focus. Seems as though the different colors separate and get out of focus.
Ur tv is having a convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 50GX30B 50". Rear Projection...
Color is seprating
Tv have a problems known as a convergence problems,it dead.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts must be replaced on the tv convergence board to fixed it to solved tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Hitachi 50EX01B 50" Rear Projection...
There is a gost and crazy color
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D colors look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must have be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Hitachi 43FDX15B 43" Rear Projection...
Red color is out of alignment
The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must require chaging to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Just a couple days ago i turned my tv on and the color images had more red then any other color
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 19, 2010 | Hitachi 57F500 57" Rear Projection...
I have a sony kp-61v85 color rear video projector and it has a red haze across the middle section of the screen like its out of focus. A tv repair man replaced 2 cv boxes and the picture got clearer and...
The tv have a problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resitors are dead.These parts on the tv convergence board,must be replaced to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Sony KP-61V85 61" Rear Projection...
Color is fine but in top right corner have blue and yellow distortion but the rest of the screen picture is ok
The tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment anywhere in the picture screen.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.
Oct 09, 2010 | Hitachi 60DX10B 60" Rear Projection...
Hi I currently own a Hitachi rear projection . And I was trying to tune he color and I think I burned the tube I have a line onbrhe screen. Is there a way to clean the picture tube or replace it
Tv colors lines R,G.B mis alignment,colors shadows pictures or 3D pictures?Yes,this tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergence board problems.Will solved the picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 15, 2010 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 61UWX10BA Convergence Still Off After Chip Replacement
Remove Front bottom Panel thier you will see front of convergence board there is a small blue contact switich with TV on press and hold it for 5 sec then you should see convergence Pattern so you can aline convergence correctly I have the whole Manual to tv just have to find it. anyway for now try this.
Dec 01, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 61UWX10B 61" Rear Projection Television Logo
625 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
