Question about Dell Dimension E520 PC Desktop
My Dell System Optiplex 520 having 160 GB Hard SATA disk drive. when i turn on my PC then show error : auto sensing second slave hard disk drive" i restart my PC several time then Turn on my PC window. Please help me about this problem that how can remove this error.
Posted by Shafique-Ur-Rehman on
Pradeep
    New Friend:
  • 28 Answers
Go to BIOS by pressing the F10 button(may vary product to product).
check the boot option, it might be changed, you need to change it for 160 GB hard disk.
If it does not works, then it might be the failure of harddisk.
Contact you Vender in this case.
Posted on Mar 12, 2014
How do I replace hard drive in dell OptiPlex 360 with Seagate barracuda 160 gb 7200 sata hard drive?
Do you want to replace it or add it as a slave drive....is your hard drive bad or just limited use...there are different jumpers that need to me set for different way of installation....do you have a new license for installing an operating system....several questions come to mind...I've replaced several and added slave units but it differs.....Can you give me more details and I may be able to assist you with your endeavor....Do you have an alternative method for accessing the internet or better yet, fixya website?
Oct 18, 2013 | Dell Dimension 2300 PC Desktop
HDD Upgrade
That model has standard IDE interface for hard drive. Don't think 500 GB or higher comes with that interface. The standard now is SATA interface for hard drives. Here is a lnk to the owner's manual for you model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-gx60_user%27s%20guide_en-us.pdf
You tell the difference between standard IDE and SATA in that the standard IDE interface uses a wide flat ribbon cable to connect to the drive. SATA uses a small thin cable as shon in the following link:
http://www.google.com/imgres?imgurl=http://www.cooldrives.com/lib/cooldrives/ultraflex-sata-cable-2.jpg&imgrefurl=http://www.cooldrives.com/24seatsaiiul.html&h=514&w=600&sz=35&tbnid=wGLj8F1otpnJYM:&tbnh=97&tbnw=113&prev=/search%3Fq%3Dwhat%2Bdoes%2Ba%2Bsata%2Bcable%2Blook%2Blike%26tbm%3Disch%26tbo%3Du&zoom=1&q=what+does+a+sata+cable+look+like&usg=__57zU4K_H2rpvq5AyZ41v_Ag4RTk=&docid=m3f9D21nEcMb3M&hl=en&sa=X&ei=NZQVUbrfDJD49gSd44CAAg&sqi=2&ved=0CFkQ9QEwBA&dur=81
Feb 07, 2013 | Dell Optiplex GX60 PC Desktop
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
I've a Fujitsu MHV2080At like external disk and from some days PC don't recognize Hard disk and this is "dead" , the led's are ok when i connect USB but the head of hard disk don0t...
  1. Serial ATA:  If you have a 3.0 Gbit/sec SATA drive that is not being detected by your 1.5Gb/sec SATA controller, or it causes your system to lock up when connected to a 1.5 Gbit/sec SATA controller, you may need to jumper your 3.0 Gbit/sec SATA drive to the slower speed of 1.5 Gbit/sec for the system to recognize it properly. For further information on changing the jumper setting to slow down your SATA drive's transfer rate, please see Document ID: 193775
    -48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA:  It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used. Please consult Document ID: 196299 for further instructions.
  2. Faulty Hard Drive
    If you have completed the above checks and procedures and the drive is still not properly detected, please attempt to use Seatools for DOS (see the tutorial here) to test the drive.  If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
Sep 19, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
Can anybody tell me detailed settings for MoBo D102GGC2 ? In actual i bought 1TB wb hard disk. But during installation process setup is not showing 1TB hard disk. It is only showing old 80 gb hard disk. ...
Go to start and right click on my computer and scroll to manage and click...Computer Management will appear on this click Disk Management.You will see the hard drives you have..If the 1TB hard drive is visible and unallocated in the status column Format hard drive to NTSF..Right click on the 1TB drive and format..
Sep 16, 2011 | Intel D102GGC2 Motherboard
Is sata 160 gb hard drive supported on dell optiplex gx240
No unfortunately it is not supported in your system.
You can maximize your system hard drive up to 40 GB.
Thanks.
Have a great day
Oct 10, 2010 | Dell OptiPlex GX240 PC Desktop
I have a dell optiplex gx 620 put in with new wd sata 500gb hard drive but will only show 130 gb
maybe the hard drive is not yet recognized by the system. try to reformat your hard drive by using disc management. got to control panel, performance and maintenance, administrative tools, computer management. under storage, click disc management, right click on the new hard disc drive and click format.
Sep 06, 2010 | Dell OptiPlex GX620 PC Desktop
Different WIndows operating systems on two hard drives
main Dell Optiplex
Slave (cable select)
Quantum Fireball
once you have installed them physically into your comptuer like that, start it up.
Format Quantum Fireball
Now you still have windows xp, and you have a clean 2nd hard drive.
You do not need to install windows xp on the 2nd drive
Quantum Fireball .
Dec 13, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Dell Dimension E520 PC Desktop Logo
85 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
