Coleman Electric Cooler 40 Beverage Cooler Logo
A
Anonymous Posted on Mar 12, 2014
How do i change the fuse on a coleman power chill cooler
Need help finding the replacement fuse for Coleman 6215 / 6216 cooler.
should be a normal glass type car fuse from any parts shop
go to the Coleman web site and contact them for the fuse specifications
I have recently bought a 40 qrt coleman eletric cooler. Has it one da y and dc plug stopped working. Replaced fuse, and checkes all volt outlets in truck as well as fuses in fuse panel they all work.
Did you accedently or spark power wires? These have a tendency to blow the diode if that happens. Also check fuse in plug of cooler. Take it apart an look sometimes the wires break.
How to remove fuse from Coleman thermoelectric cooler
Unscrew the chrome circle at the tip and it will come out.
Coleman thermoelectric cooler not cooling
Sounds like the Peltier effect elements have failed.
http://www.tetech.com/Peltier-Thermoelectric-Cooler-Modules.html
Depending on your handyman skills, you can change them yourself or have someone troubleshoot and change them.
3helpful
2answers
NEED PART NUMBER FOR THE FAN ON A COLEMAN POWER CHILL ICELESS 12-VOLT COOLER.
Visit the Coleman replacement parts web site.
www.coleman.com/coleman/parts/PartsDefault2.asp
1helpful
2answers
Coleman propane stove, tank got very cold. why?
as propane is used it can create frost on the tank or just cause the tank to feel cold. this is normal. this will be worse when the tank is almost empty.
14helpful
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Top Coleman Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Coleman Home Expert? Answer questions, earn points and help others
