Question about Minolta Maxxum 7000 35mm SLR Camera
Screws on battery cover are stripped
How can I get them loose?
Any ideas on how to remove a stripped screw from lawn mower, Briggs and Stratton, top plate, there are 3 screws and one is stripped not allowing the cover to come off
By stripped, do you mean the head is stripped, or are the threads stripped.
Head stripped = Damaged Screw Extractor Drill Bits 4 in 1 Bolt Extractor Set Easy Out...
Stripped threads = You need to "drill off" the head of the stripped screw. Get a sharp drill bit that is at least twice the size of the threads. Drill into the screw head until the entire head is gone or can be removed..Once the entire head is gone, you should be able to remove the cover..once the cover is off, you should be able to remove the screw with vise grips or other suitable tools.
Jul 08, 2017 | Briggs Garden
The stitch selector keeps turning , doesn't select stitch
1. Check for screws under the selectors outer ring. Tighten if loose
2. Check for loose screws on the front of the selector. The selector switch may have a cover to camouflage the screws. Tighten if loose.
3. If there are no screws the selector may just be pushed on. Pull forward to remove. It is possible the inside metal bracket is stripped from the plastic. Look for looseness of the center bracket.
4. Give the selector a thorough check for cracks. If you find cracks you will have to replace it.
Mar 12, 2015 | Sewing Machines
Sony vaio vgn-ar730e/b lcd is loose
Remove the strip that is right above the keyboard then you will be able to get to the screws that hold the lcd. Remove the power cord, remove the battery and look inside the battery compartment to see if there are screws in it. If so remove them because the might hold the strip above the keyboard.
Turn the laptop back over and pry the strip off gently because there might be a cable attached to it. Now you should be able to tighten the screws that makes the lcd lid movable.
May 04, 2012 | Sony VAIO VGN-AR730E/B Digital Studio...
Need to know how to change batteries, I have ten properties with schlage keyless enties
It depends a bit on the lock and how it was installed.
For the Home locks with a panel on the interior of the door, remove two screws and take off the inside cover. These screws can be at the top and bottom or through the plate of the interior door handle. Then remove the 9V battery and install a new one. Put the cover back on and replace the handle, if needed, and the screws. (Do not use a cordless screwdiver - you could overtighten and strip the threads.)
Other installations have the battery inside the panel with the keypad on the exterior of the door. To access the battery compartment, you need to remove the interior door handle or lock. Then pull the keypad section out of the door. The 9V battery will be behind a coverplate on the back of the unit. This cover needs to be pivoted downwards to open the compartment.
The Schlage commercial offline locks (no computer monitoring) use AA alkaline batteries (4 or 8) in a block. The eight battery version has 4 batteries on each side of the block. These are all on the inside of the door. Remove one screw to get the cover off. Then remove two screws to get the battery holder off (this keeps the batteries from coming loose in the block). Replace all of the batteries and resecure both the battery holder and the cover panel.
For the consumer Schlage Locks manuals, see http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx . For information on the Schlage commercial locks. see http://commercial.schlage.com/electronicsecurity.asp . The manuals are available in the Technical Library for each lock type.
I hope this helps.
Nov 20, 2010 | Schlage Locks & Locksmithing
Pavilion dv4 1431us how to remove the hard drive. Don't know which section is the hard drive screw to unscrew.
The Battery Compartment Cover is to the outside.
(By the way. Have all power sources removed from the laptop. The AC adapter {Charger}, and the Battery)
Laptop upside down, face the Battery Compartment to the top.
The long middle cover in the middle, under the Battery Compartment Cover is the Harddrive Compartment Cover.
On the Left side of the Harddrive Compartment Cover are two screws to remove. One in each outside corner.
After the screws are removed, lift up on the Left side to remove the cover.
(They may just loosen to a loosened state, and not actually remove)
The Harddrive Compartment Cover is 'hinged' on the right side, with a couple of plastic tabs coming from the cover itself. After it is tilted up far enough so that these tabs will come free from the slots they're in, the cover can be removed.
There are 3 screws which hold the Harddrive Caddy in place. (The Harddrive is mounted to a sheet metal Caddy, which goes across the top of the Harddrive, and down each side)
The first screw is in the Middle to the Left outside.
The other two screws are on the Right, and are on the corners.
After removing the screws you will see a Black strip of cloth/plastic coming from the Left side of the Harddrive/Caddy combo.
The Harddrive is eased up slightly on the Left side, and pulled to the Left side with the strip of cloth/plastic.
(On the Right side of the Harddrive is the interface. The pins that come out of the Harddrive. These pins insert into a female socket in the laptop)
The Caddy around the Harddrive is mounted to the Harddrive with 4 screws.
Two on EACH side.
Holding the Harddrive in the direction it came out of the laptop, (Interface pins to the Right), look at the mounting screw on the Right side.
The one that goes through the sheet metal Caddy, and fastens it to the Harddrive.
Now look at the same screw on the Left side. It goes through a tab.
Remove these screws, and DON'T loose them, or mix them up with the other screws.
(Use a multi-compartment container. You can use a clean egg carton in a pinch)
Remove the screws from the other side.
Install the new harddrive in the Caddy, then install the Harddrive/Caddy assembly in the laptop.
DO NOT overtighten the screws.
Regards,
joecoolvette
Oct 18, 2010 | Computers & Internet
HP DV9000 My laptop screen is loose i would
When the laptop is flipped over, remove the battery. Under the battery there are 6 screws placed in pairs, these have to be removed. Once these are removed, the speaker and power strip can be pryed up, start with your finger nails on the right side and pop it off. Be careful with the flat cable in the middle of the strip. Tighten the screws for the display there and I think there are some that tighten from the bottom. Also, remove the rubber pads from the screen bezel and remove the screws from the screen bezel, then pry the bezel off at a corner and work your way around the bezel until it is removed. It will somply snap back on when you are finished. Tighten all the screws you see that connect to the hinges, this is wher the screen loosens alot. Just pay attention to the wires that feed through the bezel from the screen to the motherboard. Take your time, nothing to it.
Aug 22, 2009 | Frigidaire FRT17G4B Top Freezer...
Remove interior door panel on 2003 BMW 330I. The window is binding. Trying to get panel off so I can see what it is.
I am assuming that you have a 4 door sedan. If you want to remove the front door panel, it is held on with 4 or 5 torx screws, Under the armrest you will see 2 plastic cap covers. Gently pry the covers loose and the screws are inside. T20 I think. Where the inside release handle is you probably have a decorative strip(wood grain or painted plastic). At the end farthest from the handle, use a plastic wedge, or flat popsicle stick to pry the corner loose and gently pull the strip toward you. There will be 2 more screws under it. If your door has a plastic airbag emblem there is a screw under it. Otherwise there should be 1 screw hiding under the mirror switc on the armrest, or mirror switch cover. Using a small flat edge wedge pry between the panel and body at bottem until the panel pops loose.work your way around the entire panel. The top panel near the glass pulls toward you. Once the entire panel is loose, grabbing the armrest,pull the panel straight upwards. Be careful when pulling up as to not pull too far. Your inner release cable is attached on the backside. When reinstalling the panel make sure that the rubber grommets are on the panel clips..they help keep water out.
Mar 15, 2009 | 2003 BMW 330
Battery cover replacement for the Dimage Z2
to get to the battery door you must remove the back, to remove the back you must remove the top of the grip (shutter button and dial and WT lever). remove top of grip... 1) starting at the bottom of the plastic strip (along the front edge of the grip) that holds the shutter button, slide upward, the strip will bow outward and after about 3/16", the bottom's free. the only other thing holding it in place is a bit of double-stick tape and a similar clip at the top. CAREFUL! there's a spring under the button that's easy to lose. 2) Inside the battery case, front battery, all the way at the top, there's a tiny phillips screw, pull it. 3) peel away the right side rubber grip right by where your thumb meets the W on the W/T lever. 1st hole you'll see is a springy clip, keep going around to the right til you find a screw. pull that. 4) back to the springy clip hole, pushing inward on the finger, the top will come off straight up. leave it hanging, you just need it out of the way so the back can come loose. remove the back... 5) bottom of camera, remove 2 screws nearest the CE label and one outboard of the rearmost battery. 6) viewfinder cap: 4 screws, skinny on top, fatter on the bottom. the cap pops off. 7) lcd cover/frame: pull away from viewfinder(top) edge about 1/4 inch. the bottom's held by fingers; they need to slide to the left 1/8", then that's off. 8) remove screw @ lowerleft of lcd. now the whole back will slide rearward. 1st thing loose is memory door, remove it. slide the back off, out of the way. you'll now see that the battery door is held on by two hinge pins, not one continuous. the rearmost pin will slide left into the memory cover area, and the door will flex enough to remove it toward the front. trickiest part of reassembly is the spring under the shutter button. balance the spring on the camera, put the button into place. hold it in place with the screwdriver through eye of plastic strip, leaves plenty of room to seat the strip. lose a screw? I did, and the least-needed one is the one pulled at #3. NOW who needs to buy a battery door? I have a z3 with a fried power board.
Mar 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
Replace Battery Cover
Oct 04, 2006 | Konica Minolta DiMAGE Z1 Digital Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
75 people viewed this question
Top Minolta Photography Experts
Ekse
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
