Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Formatter I have green and black lines...no picture and no audio,,,was told i need to replace the formatter...is this hard to do?the tech said it cost over $700...
Posted by kfletch on
Anonymous
  • 39 Answers
HEY KFLETCH THE TECH SOUNDS RIGHT ON,AND THE REPLACEMENT OF THAT BD. IS A BIG AND TEDIOUS PAIN. I SUGGEST LEAVING THIS TO THE PRO AS IT MOST ASSUREDLY WILL SAVE YIU MONEY AS WELL ANGUISH.JOE TV
Posted on Nov 12, 2007
Screen shows light with crack, cannot turn off
Internal defect needs factory service. Module inside needs replacing and you cannot do that.
Mar 25, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
No picture.
The problem is with the ic's which will have to be replaced to fix this problem.
Apr 09, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Screen is black with two green lines when on. has
sound like you last vertical sweep which is ususally the output ic you will need a tech to verfiy it
Dec 06, 2009 | Televison & Video
Picture at top of screen, bottom half is black...middle of screen has horizontal red, green line which is slightly bowed upward. model # is GE 46gw948
Call a good TV Tech and tell him the Convergence Amp IC's need to be replaced. Should not cost over $325.
Jul 29, 2009 | Televison & Video
Dell XPS 1330 - screen goes funky with lines memory parity error
the tech is saying that they replaced the motherboard and if they replaced it with the same model number and the manufacturer didnt fix the problem you had to begin with then the new issue is just a mirror of the old one and will require a Motherboard to fix.
Jun 22, 2009 | Dell XPS M1330 Notebook
Picture is green.
I also have this problem, anyone get a fix yet?
May 19, 2008 | Samsung HL-R6167W 61" HDTV
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Sanyo television
Susie, you either have a shorted green drive transistor or more likely a shorted cathode inside your picture tube, transistor repair is a cheap fix, picture tube means set is not worth cost of repair, hope this helps
Nov 27, 2007 | Sanyo DS25390 TV
Static-y picture and sound, menu visible
i have the same problem but i just baught a new lamp and i am hoping thats the problem...
Oct 15, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
