Question about Eddie Bauer 3-In-1 with Latch
Relacing straps I had removed the straps for cleaning, but now can't figure out how to put them back on properly. Can't seem to find the manual. any help finding the instructions?
Posted by damarde on
  • 10 more comments
  • Anonymous Nov 02, 2007
    NEED HELP WITH PUTTING THIS CAR SEAT BEACK TOGETHER AFTER WASHING
  • Anonymous Nov 12, 2007
  • Anonymous Nov 17, 2007
    i can't lace the straps
  • rose369 Jan 01, 2008
    took the car seat apart to clean now I can"t figure how the straps went
  • Anonymous Jan 04, 2008
    the harness i need to make it longer to anchor it to the veichel
    the harness i need to make it longer to anchor it to my van.
  • Anonymous Mar 03, 2008
    Washed car seat cover. Can't figure out how to relace straps. Help
    [email protected]
  • Sashch Apr 07, 2008
    Trying to ajust the middle strap thats between the legs
  • elly24 Apr 08, 2008
    i need to remove the base of the eddie bauer 3 in 1 with latch carseat
  • my2boys Apr 27, 2008
    My fiance took the straps out to wash the cover of the car seat and now can't figure out how to properly reattach them. PLEASE HELP ME!
  • mother0506 May 14, 2008
    removed straps to clean set, I can't remember how to put the straps back in
  • Anonymous May 16, 2008
    TOOK STRAPS OUT TO CLEAN , CANT GET THEM BACK IN CORRECTLY ... MODEL # 22-864-LRS .. PLEASE HELP AS MY HUSBAND IS READY TO THROW IT OUT MY WINDOW !
Anonymous
    Problem Solver:
  • 6 Answers
Try looking on the website
from the picture it looks like the eddie bauer 3 in 1 car seat
http://www.coscojuvenile.com/instructions/
here is the link for the web site, just imput your model or product code and you will be able to download the instruction manual
Posted on Nov 02, 2007
I have a Cosco car seat model # 02-848-BNG. I took the seat apart to wash it and can't figure out how to put the straps back on properly. Please help me. Thanks Penny
I went to the Cosco website to get a manual for you and they also need a date of manufacture. If you can obtan this, here is the link to type in your model and date. I expect the manual will help you in the strap reassembly.
http://www.coscojuvenile.com/usa/eng/Instructions
Hope this helps... Good luck!
Sep 16, 2009 | Baby Gear
Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
Someone removed all harness from my Cosco, Summit car seat. I cannot figure out how to get them attached and will not do it without knowing I have done it safely. Help!
My daughter has a car seat just like this one, and I wash it about once a month so I hope I can explain this detailed. First, at the base there is a metal rod that will need removed. When you take this rod out the base and seat will seperate. Set base aside and turn seat upside down. Take your strap and put an end into each slot. Turn seat over and pull your straps even. Put the two black pieces for your latch on (one on each side) then put you chest pieces on and run straps thru slots on back of seat. Turn seat around and make sure the straps go OVER the silver bar in back (this allows you to adjust shoulder height) Secure to the metal piece that runs to front for tightening adjustment. Sey seat back on base and replace rod. Hope this was helpful.
May 04, 2009 | Cosco Summit 22260 - Houndstooth
Rear Facing UAS strap can't feed through?
Are you sure you're looking at the UAS/LATCH strap and not the top tether?
Your seats should have a long strap with a hook at each end that goes through the belt path (the UAS strap) and another at the top, for top tethering once you turn them forward facing.
The UAS strap may be hooked onto the sides of the seat or bundled together underneath...take another look at your manual to find out where they store it.
Alternately, install with the seat belt - neither LATCH/UAS or seat belt is "safer" than the other...the LATCH/UAS is just supposed to be more convenient.
Jan 03, 2009 | Eddie Bauer 3-In-1 with Latch
How to remove cushions
Contact Peg Perego & they will give you answers over the phone or send you a manual for free (email or snail mail).
800-671-1701
Sep 23, 2008 | Peg Perego Tender Blu Moon Twin Seat...
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Eddie Bauer 3-In-1 with Latch Logo
731 people viewed this question
Top Eddie Bauer Baby Gear Experts
superdad1976
Nikki  Mclean
Nikki Mclean
Leakfixr
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
